I couldnt be bothered reading all the replies (consumed a bit too much beer) but I had a problem with my left headlight too. It kept going out and then coming back on and was giving me the shits. I found that if i wiggled the switch I could make it come on and off too.
So I bought a new switch from a guy who had a spare dash, and changed the switch over. Now I havent had the problem since.
If someone hasn't already suggested this .... hope it helps and good luck :)
https://www.sau.com.au/forums/topic/9667-headlights/page/2/#findComment-169849
I cleaned mine today but nothing...well my right light now works fine, as this was iffy before.
Got the trusty test light out and checked the signal to the light. This was all ok. So I know a signal is getting to the light.
So is my bulb blown? How do I take out the light to check this?
https://www.sau.com.au/forums/topic/9667-headlights/page/2/#findComment-179442
After using a different set of globes, i found that this new set were round 2mm longer, and i havnt had a problem yet. I imagine my problem is to do with the connector terminals...
To take the globe out,
pop the bonnet,
unscrew a black cover,
pull back the waterproofing cover,
unplug the power clip,
and on the base ull feel 2 prongs, squeeze these together, and the globe will loosen
https://www.sau.com.au/forums/topic/9667-headlights/page/2/#findComment-179481
hey man .. the other night my light all of a sudden stopped working .. but it was working the night before .. it got a 33 so it might be different ... i was like .. shit i gotta buy something else ... money money money ... so i asked around to see if anyone could fix it ... a member here told me to hit it the light ... i was like ... wtf?? whats that going to do ... anyways i was desperate and was going to try anything ... so i went outside turned on the lights and hit it ... first hit didn't do anything ... then second hit was like magic ... the light turned on to full brightness ... i was stoked ... rule of thumb if it dont' work .. HIT IT!!! :D
https://www.sau.com.au/forums/topic/9667-headlights/page/2/#findComment-179496
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
