hi all,
Cruising into work tonight i decided to have a bit of play, shifted into 4th at high revs and wastegate didn't open (couldn't hear screamer) and i'd lost boost. I can hear turbo spooling but not coming onto boost. I pulled over and car began to idle really rough. I'm not too sure what's going on, any help will be appreciated.
Car mods:
GT35/40
PowerFC
FMIC
Blitz spec R Boost controller
bosch 040 pump
turbosmart ultragate into screamer pipe
550cc injectors
Turbosmart BOV
Thanks.
haven't been able to really check anything yet, cause i had to get to work. But there was no loud bangs or anything.. Definately gotta check everything out tomorrow. I'm hoping it's just something simple.
I don't think it was makin boost, or very low - not pulling as hard.
Yeah, check for leaks on the intake side. Your wastegate won't open until you hit a certain level of boost, but your turbo would still get spooled.
You should take it easy, since it therefore means your turbine speed isn't being regulated anymore.
Any leaks in the intake would cause rough idle, and stalling issues. Just ask any n00b who sticks a venting BOV, with the spring set loose, on their car.
would that cause the rough idle though?? i'll check her all out in the morning and get back to ya. thanks
i have blown 2 IC hoses since my new install went in .. pretty close to yours.. only thing is that my car wouldn't run AT ALL with the hose off.
could be a split in a silicon hose enough the limit boost but allow air though..
only other thing would be turbo seizing.. or gate stuck open..(but you would notice the noise with a screamer pipe..
good luck.. hope it aint nothing major for you.
hey all,
thanks for all the help, i actually found the source of the problem. I've got my Z32 in series with the intercooler and the Z32 had actually cracked underneath. Replaced it and running like a beauty again.
B)
Z32 is right before intake plenum, sits right near the top of the radiator.
I'd have to agree on the abuse side. <_<
Edited by AlpineFreak
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
