Hi guys for awhile now Ive thought that 2530's are crap as mine seems to be very laggy top end is great but there is almost no bottom end.
To give you an idea turning down a street 2nd gear foot flat I can almost drive 100m before the rev;s will pickup enough to starting making any boost. Dragging or flat straping it to keep it on boost is fine its more like roll on type events.
At drifting Monday night I was clutchie 3 or 4 times while stock turbo'd 32's were having a ball
Anyway I let a mate (softy on here) drive it the other day as he has one fitted to his ceffy he confirmed that it is very laggy compared to his or even Huddy's cefiro (which is colser to mine in mods)
things I have tried and thought it might be
1. moved Act feed line from front of comp cover to manifold (seemed laggier)
2.d odgie fuel pump I have a walbro but I could have been sold a copy although it has the stamp( Im thinking this as my car feels very doughie going around corners which is the same as my 180 was when its fuel pump was dead)
3. Fuel filter (I have not changed it ever ) looking into that today
4. the stock black hose from Act to comp cover is around the wrong way Im not sure if they have a right way but if they have a restrictor in them it may cause a problem.
5. wastegate is stuffed i.e leaking
6. hks adjust Act is stuffed although I have tried to stock one and it didnt help
7. stock BOV is opening?
8. car needs a remap as the fuel ratio's are around 10.1 making the car feel flat until full boost were the fuel is being used
9. car needs a boost controler (not sure about this one as Ive got the hks act and it feels really laggy not a little bit which a bc might help
on the stock boost gauge my car in 4th 60km sit's just below the mark before zero(sorry hurt my foot so Im driving my g/f car today so I cant look at how the gauge goes)
were does yours sit?
a guy I spoke to the other day with a t3/4 said his sat just under zero 4th gear 60km
oh and a vg30 on a rb20det feel's better than my 2530 bottom end wise
https://www.sau.com.au/forums/topic/96705-hks-2530-poor-boost-responce/
twin 2530 or single 2530? sounds like single 2530. what exhaust setup do you have? so no boost controller just plumbed directly to the actuator. have you checked for any leaks in the cooler piping / joiners?
thanks guys yep single turbo no twins (not sure were you got that from)
I have a advance front and dump pipe three inch,
yep no boost controller but I have adj hks actuactor
I have checked all the piping joiners etc (intercooler piping has been on and off the car a few times)
I have had it on the dyno in front of me couldnt hear any leaks
here's a pic of it onces it's on boost after clutching for the 4th time and running 185/50/15's on the back
Edited by 1400r
fair point cubes but why's it laggier than Huddy's car (he has no pfc or b/c he just has a fcd) I bought a fcd off riverside didnt seem to like my car though wouldnt idle.
I was thinking of leaning of the afr via my adj fuel reg (on a dyno) to see if that helps either that or I'm gonna sell it once some of the cars Terry has coming over arrive.
Interestering you say you run an adj. fuel reg bleeder.
I used to run one of those on my RB20DET with stock turbo at 1bar and an external bosch pump.
My RB20DET used to run fairly lean through the mid range without the bleeder, using the adj. fuel reg worked wonders for top end power as it pulled it out of the 10:1 afr's.
The problem was to lean out the top end you also have to lean out the already near lean mid range, leaning out furthur made my mid range suck, it felt dougy then all of a sudden it would scream out.
I always got good fuel economy I assume due to the leanish mid range the stock ecu would give, 470km's to a tank running around locally or just over 600 on the open road. I never used to drive it easy, always in to it.
I ended up pulling off the adj. fuel pressure bleed off in favour of more mid range. Give it a try, it may drop the afr's just enough for the mid range and spool to come up.
With the fpr bleeder set not to bleed it still causes a slight delay in the fpr seeing boost and still does cause it to lean out slightly, I found mine would slightly ping if jumping on the throttle 4000rpm+ due to this.
My experience with the fpr bleeder is that it works really well with very minimal mods, in my example an exhaust, stock fuel pump, stock ic, stock turbo at 12psi.
But yer pull off the fpr bleeder and take it for a spin, it may pick up the mid range. It did with my stock turbo running 1bar.
I've got a dyno graph of the lack of mid range due to the pfc bleeder, you can see the torque come up flatten then all of a sudden pick up once afrs go richer. Its a pitty I didnt get the afr sheet.
This was back when Tim (rpm & horsepowerinabox owner back then) just started selling the fpr bleeders.
Edited by Cubes
yer, good idea to see what it is doing by a dyno session.
Could be (as is so common) more boost was causing the ECU to be very much un-happy causing the car to be worse!
All your listed things, have you actually checked any?
as a few (#9) arent required etc.
Also, get a boost gauge. I wouldnt be trusting the stock item to give anything resembling an accurate reading
One more thing...
1400R, you said it sits at 0 at 60km/h... What do you mean by this? Do you mean it goes to 0 vacuum when you floor it or does it mean that when cruising it sits on 0.
If its sitting on 0 while cruising then check the little rubber hose going to the factory map sensor that feeds the std boost guage its reading.
My steps would be... Rip that fuel pressure reg bleeder off, if that does help spend the $35 and throw it on the dyno to see whats going on, AFR wise.
Blackwood auto & dyno also have a tool to plug in to the consult port.
Edited by Cubes
Thanks guys ive had it on the dyno both at morpowa and at the sau dyno day here in Adelaide. Cubes Im going to take adjustable fuel reg of tonight as you might be onto something and Ill spin the black Act hose around.
When Im cruising it sits just below the mark before zero so when I put my foot down it has to get to zero
sorry for the confusion guys
diff + toe + pain killers = brain no workie
Yep I have a blitz boost gauge just not sure of the vac numbers it runs while cruising on it as it in the air con vent near my leg so I dont look at it much unless full boost checking
car sits on -60 at idle though?
Blocked cat is what softy suggested so might be worth a look as he also commented on how quiet my car was, although when I put the front pipe on the cat appeared to be fine from the front anyway.
Dyno run with the higher line is with a bleed valve running of the fpr to try and bring the ratios down(must have been quicker than adjusting the fpr itself) mind u this run was at 11psi Im now runing 1 to 1.1 bar
Not sure if its comparable... On the stock guage the RB30DET @ 60km/h on cruise sits at around -5.5x100mmHg.
Idle is ~ -6x100mmHg
The file doesn't appear to work. :O
Save as jpg?
Edited by Cubes
Edited by 1400r
Looks ok at that boost level.. No doubt more boost will get it running lean pretty quick. :)
Pull it out the fpr bleed see how it goes.
Boost is also super linear... which is strange. :D
Edited by Cubes
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
