There have been a number of different hardware solutions for interfacing with the Consult port on Skylines. There are some excellent Group Buys with handsets and interfaces for lap tops. There are also number of downloadable software options around, some free, some with small fees. The idea of this thread is to have an ongoing discussion about what software and hardware people are using how they are finding it, what sort of benefits they are getting and maybe even some tricks and tips that we can share.
So please feel free to drop your thoughts into a post.
>_< cheers :(
https://www.sau.com.au/forums/topic/96708-consult-interfaces-software/
  • Replies 114
Posted Images
I will kick it off, I have a Newkleer DIY kit interface (see Group Buy section) that I use with my lap top. The kit was easy to build, but the USB to com port link was a bit tricky to get working.
I am using the Calumsult software, free download via a link in the Group Buy. I find it OK, the only complain is that it is imperial measuremts (eg; MPH) which can be off puting at first. The lambda sensor readings (O2) are not calibrated (volts only shown) so I will have to make up a conversion table.
This is a grab of the most common screen I use;
Picture to go in here;
I haven't done very much logging yet, but I will start that tonight and run it for a few days and see what it reveals. I have already detected a spark plug missfiring by the sometimes eratic lambda readings, this is very noticeable at idle. When it should really be stable running closed loop.
Sample log to go in here;
That's enough for this post.
>_< cheers :(
I've found the 'telesis' usb-serial adaptor ($45 at Harris technology)
worked perfectly with NewKleers consult unit.. Had no issues using it to interface with either of my 2 laptops (old and a new one) if that helps anyone >_<
The usb-serial adaptor worked perfectly with the 3-4 main software programs..
Also a little tip to getting the usb adaptor in the right direction is to make sure you change the com port of the usb-adaptor to one of the com ports not in use between 1-4, as thats what most of the software applications can only use/detect.
I have the plms cable and nissan consult (the $25 one) and I can do some sreen shots if you wish. Can't datalogit as not using stock ecu. I found this consult the best out of the ones I tried. I tried free conzult, the 300zx one and another free consult one. Nissan Datascan is the one I paid for (and can do screen captures if you want)
worked perfectly with NewKleers consult unit.. Had no issues using it to interface with either of my 2 laptops (old and a new one) if that helps anyone :O
Ports 1 to 4 were used on my laptop, that was the problem. so it took me a bit of fiddling to get it moved to port 5 in the Calumsult. Once I did that it worked fine.
:D cheers :)
Maybe if you guys can list which model this applies to?
Like does it apply to RB20/25 & 26 inclusive? Or are there separate ones for each ECU type etc.
Could become a sticky as this is some good information for those inclinded
The Consult port and its matching terminal in the Nissan Dealer service department, has been around for many years on all models of Nissan. Certainly all modesl of R32/33/34 Skylines and Stageas have Consult ports. The common interfaces/handsets work on all the models that I have tried.
:O cheers :D
I have used the PLMS consult cable with datascan and found it to be very useful, Untill I tried to use it on a cefiro. and being pre 1989 the plug was different and i could not use it.
Does anyone know of a conbroad minded person cable that will work with
Cefiro's, Glorias, cedrics, cimas, leapords ect ect.
My knowlege in this area is very limited so any help would be greatly appreciated.
I'd be intersted to know if anyone has wired a consult plug into a loom.
I could see this being useful for conversions were the newer engine in and older car loose's out.
I have found this on the net previously. Not sure how accurate it is.
Just for those doing swaps and want the CONSULT port (Techtom plugs into CONSULT port) to be functional on s14:
on the F3 Plug (KA):
#22 G - Transmit
#23 G/W- Clock
#38 G/B- Recieve
For Techtom only these three wires are needed. On SR and RB there is a fourth wire "check signal" that is not needed for Techtom to operate.
On RB:
#34 Y- transmit
#38 Y/R- clock
#39 BR/Y- recieve
Has anyone also had success downloading an ECU Rom file(bin) using the consult ??
I have tried it using nissandatascan on R32's and it seems to sit there and do nothing.
it works all rb20, rb25 (r33 only), doesnt work on er34 as they have oBD version II which the consult software / plug is different as far as I know. this should work on gtr32 and gtr33 fine with stock ecu. i have cable and software if anyone wants to borrow / test . also works on most nissans from 89 to 98 ish. works on pulsar, silva, 200sx etc
Has anybody tried the full version of Datascan? and what did they think?
Calumsult requires win2k and my old laptop only runs win98 unfortunately.
I got ConzultFree working, but obviously its very limited... and its a bit expensive for the full version.
i had the full version of datascan, i dont think it was anything special.. the other 3 programs available for free were just as good.
That 300zx program i cant remember what its called, but it was HEEAAAPPS expensive, that looked realy cool though :D
I built my own usb consult cable. (being a tech has advantages at times :) )
I've used conzult free version and I have used the datascan and I find the data scan to be the best for my application.
Though I would love to get my hands on the full conzult software.
I haven't really done much with the datalogging yet just mainly used it for its map tracing etc.
the interfaces should work on any car with the 14 pin grey consult connector. unfortunately this doesnt include A31, S13/w CA18, and some of the other nissan models that started around 88 (cima/gloria/etc). it works on the R34 also (someone said it didnt?). only works on r32's built oct or nov onwards i think? definitely the early ones it didnt work on (again, if it has the 14 pin plug it should work).
some consult interfaces wont work on all models (eg soem have problems with r34), but the kit i made shouldnt have any problems (and recent plms ones should work too)
ive recently started working back on my consult app (pocket pc version in the works too), and have got serial number, fault codes, sensors done, still with active tests and rom dumping to go. unfortunately it doesnt look that "pretty" so far
any suggestions on what parts of different programs everyone finds useful, how gauges should look, and so on would be good - i basically have no real artistic ability at all so making things look pretty isnt one of my strong points :)
Edited by NewKleer
I did a bit of logging last night and the first thing I noticed was the lambda sensor readings where all over the place. I have never played with a standard lambda sensor before, all of my experience is with F&W ones.
After it warmed up the idle lambda readings where around 0.2V, as you would expect for closed loop running. But after a good thrash it would never drop back to there, it stayed at 0.7V, which is very rich. This a new lambda sensor, so I know it isn't that.
Anyone else had that experience?
:( cheers :P
could u post my logs?
my experience is that with a properly operating o2 sensor, eventually at idle, and cruise it will get into the swinging pattern of going to like 0.1v->0.9v and back continuously (as it should, given theyre pretty much only a "more than 14.7:1" and "less than 14.7:1" switch (hence the lean/rich switch available by consult - im guessing the ecu only checks whether its more/less than 0.5v and thats it.
calumsult graphing is very good at showing the o2 sensor operating
after a good rev, often the o2 sensor will stay rich (i think thats > 0.5v?) for a while until things stabilise, normally say 10s then it goes back to swinging (assuming your in closed loop mode - cruise/idle).
Edited by NewKleer
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
