  • Replies 114
Posted Images
quite possibly that would just be from an external accelerometer than something in the ecu? what other things are on the dash? if theyre largely mechanical type things (rather than typical sensor readings from consult) then id say thats what it is
does it say anything in the service/user manual (if there is one?)
Edited by NewKleer
The R34's show the G-sensors digitally on the dash for 2000 models up, and mechanically for 98-2000 models.
The R32 GTRs and GTS4's have a couple of G-sensors around the place, but you don't get to see what they're doing. I think they would go to the ECU though.
I'm pretty sure the g-sensor would need to report to the ECU for ATTESSA functionality, unless of course there's a sperate unit/controller for it...
Also, just to confirm... HICAS is also controlled from the ECU? Or does it just manage the steering angle sensor and the like somewhere else?
Re: G-sensor ECU input for R32 GTR. The last few pages are the relevant section. It's the Autospeed article on the R32 from years back.
Thanks for the article, which for those that havn't read it, explains how to intercept the signal between the accelerometer (g-sensor) and the ECU. Which also allows for modification (i.e. piggyback system).
However, what I'd like to do, is read the sensor output voltage from the ECU (via the consult port)
Suppose we could try some reverse engineering.
trying to read g-sensor via consult port would mean reprogramming the ecu (and knowing how to do something like that). would take 5% of the time of that to just read the voltage directly from the sensor.
The documentation I have read implies that there *is* a consult port (that is, it had an id byte after a two byte initialisation)
it just doesn't seem to be wired up.
Of course, I could be wrong.
though it appears that all the computers get *all* their data as sensor voltages.... ahh, the possiblilties are endless
(when I make that attessa controller, I'll share it with confidence - as opposed to state my theory and get shot to pieces)
While I'm at it, I'll ask this question:
What are the inputs to the hicas computer, AND how does it control the pump (r32).
heck - the same with attessa. I have partial information on the input, none on how it controls the centre diff.
I suspect I'll need to get at it with a multimeter one day...
supposedly air con, hicas, and auto transmission can be queried via consult protocol, but ive never had success. i saw a table of whats supported in what vehicle, and i think the common cars only support ecu, whereas gtr and z32 (which ive never tried) support some of the others
Consult and Conzult work with AirCon, Hicas and Auto Trans in the Z32's. They each have their own seperate control unit but all read from the DDL.
quote=NewKleer,31 Jan 2006, 06:26 PM]
have released an alpha version of ecu talk while or work on the consult lcd
http://www.ecutalk.com
needs .net framework 1.1, links on the downloads page there
Edited by NewKleer
on my r32 gtr the hicas ecu wont respond to the initialisation unless there are delays between bytes but the engine ecu responds with no delays could be to do with the extra distance to the hicas ecu in the boot or even the different processor used by hicas, my ac ecu also remains silent with no delays but i have only just discovered
the need for delays and have not tested for the aircon delays yet.
i read that plms have to send initialisation more than once sometimes they are possibly not using delays.
my hicas responds to hex ff ff e4 with 10 then i send d1 f0 hicas then streams the error codes FF020000 ff start byte, 02 number of data bytes following, 0000 error code bytes ie no errors when ignition was last turned off
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
