Hey guys, I need to replace my caster rods or at least the caster rod bushes on my R33, does anyone know a place in VIC close to melb that will do a good job? and would they stock the bushes or rods?
cheers,
Din.
Din,
Best to pair the caster rods (or bushes) with a camber bush. Reason being that winding in more positive caster will reduce the static camber. If you are out of adjustment on -ve camber you will be simply trading more +ve caster for less -ve camber. In short losing -ve camber at the across the range of steering lock for more -ve camber when lock is applied. (Hope that makes sense)
The solution is to use a camber bush as well as the caster rod/bush to get the gains of the increased caster without losing the benefits of -ve camber.
Cheers
Richard
https://www.sau.com.au/forums/topic/96712-caster-rods/#findComment-1756252
