no way, R33 seats wrap around a lot more than the stagea seat, much more bucket.
Yeah ... say that again. Driving the stagea is like driving your lounge chair, where as the 33 seats tend to wrap around u more.
And now l read this thread, as l could of checked the whole matt thing sat night when at a freinds house who own's a r33 gtst.
  • Replies 76
Posted Images
I think the best way would be if someone with genuine mats could make patterns from them, we can give them to the manufacturer and they can make copies, I've even got a pic of the stagea logo that could be embroided on them :(
Just need to find someone with genuine mats thats willing to put in a little time to help out us non genuine mat owners :)
Anyone interested?
  • 3 weeks later...
  • 5 weeks later...
Update,
I received the original mat tracings from bwilkeson (cheers again mate), i got some custom logos made up for myself, and i've posted it all to the manufacturer, i'm just waiting to hear back from them now.
Shouldn't be long.
I'll post some pics when i receive them, see what you guys think, and if theres enough interest we should be able to setup a group buy :(
Thanks mate, all is well with me, we're very lucky at the moment, she sleeps most of the time, only wakes up a few times a day for an hour or so, have to wake her most times for a feed :( hardly cries at all, so we're savouring it at the moment lol.
We were very surprised, the birth went very quick an easy, she was discharged the next day, I'm extremely happy with the way things went.
WOW - all up sounds like a 1 in a 1000 baby! so well behaved, very very lucky! Ours cries lots, always awake, always wants to be picked up, etc etc.
BUT - 5 weeks old now and laughing, gurgling at us, etc, looking to communicate. Great fun.
Congrats again
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
