Hacis kebabs was the absolute SHIT! shops never compare to those dodgey little caravans.
even the one that was on south road moorabbin was king!
Tripple meat... buckets of sauce... if u arent on the toilet for half a day the next day and your breath and body dont emit garlic stench for a week they aint making it right!
  • Replies 64
I must say i do enjoy a the lamb kebab experience.
Typcial lamb kebab order would be double meat, lettuce, onion and double garlic sauce. Its what i like to refer to as the "full bad breath pack"
Working in sunny Dandenong also means i have a large selection of quality kebab outlets. My choice - Donner Kebab in Yarramen. Its a bit of a mission to get there (driving past the dandenong train station and trying not to get car jacked or have my HSV maloo R8 jacked up whilst sitting at the traffic lights and having the 19inch wheels stolen from underneath me) but its defenetly worth it
Donner Kebab in Yarramen - I salute you :-)
Chicken is for woman, honestly.
Kebabs are LAMB, and only lamb.
First time i had a chicken kebab was in london, because those Poms all eat chicken, not lamb...it sucked.
Your not all POMS are ya's?...huh...huh huh
It might not just be coz they ALL prefer chicken, the cows n sheep in England are diseased. LoL.....i didn't eat any either when I went.
seriously it depends on what you feel like at the time, but i tell u what - lamb is chosen 19/20 times. The 20th time is becuase i trip out every now and again. Garlic sauce 4 sure. Apparently chilli and bbq is da bomb but i can't stand wasting a good kebab if i don't like it, so i'll stick with garlic until the joint runs out of it.
theres no way i'll waste a good lamb kebab with any of this fairy chilli or bbq sauce caper...
Best Kebabs in melb - In the north I rekon
Katiks - Its on Barry Road In Broadmeadows opposite the Ford Australia Factory.
Katiks is probly the best kebabs ive ever had - reccomendation - 1 Lamb Shish + Bbq sauce.
The other places up north here make a kebab that can satisfy your hunger - but Katiks make you leave feelin like U need another one!
btw... something I gotta clarify... wtf is up with you melbournians using The land of goat sphincter rings bread or whatever the f**k to make a kebab with. It has to be in a pide (lebanese bread).
Seems like the only guys that get this concept are the guys selling out of trailers (which are the best kebabs anyways) like Hachi's on Bell St and Katiks out on the Hume.
The number of times I've had arguements with "gourmet kebab makers" like over them using The land of goat sphincter rings bread... because that's a frikken souvlaki, not a kebab.
The land of goat sphincter rings bread with kebabs, not a fan of it. ruins the taste and its too hard to eat it like that
the place at the shopping centre here "shawarma" use the good thin pita bread....
just finished my lamb kebab just before actually. and a lebanese cheese triangle to wash it down
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
