Hey guys. Don't know if there's already a thread on this. But just wondering if I could get a bit of advice. I've had many mixed opinions about this topic.
I currently have and R32 RB20 (4 Door) with just the right amount of mods. I've done what I can without taking that next big step... Turbo choice!
I'm think I'm tossing up between a GT28 RS or maybe a GT2530 or or somthing similar from the Apex-i series or the TD- series. All proper precautions have been made.
Just after some feedback, thanks guys.
Sava.
fulllock.com
https://www.sau.com.au/forums/topic/96728-turbo-choice/
True that. GTRS huh? That's what I was thinking. I mean, I'm not after massive amounts of power just something a little more punchier than waht I've got, something that will light them up with ease.
Although I've heard that the TD-05 could a likely contender. Might be a little easier on the pocket as well.
Anyone have one on their Skylines or know anyone who has?
Any info... Cheers.
Sava
https://www.sau.com.au/forums/topic/96728-turbo-choice/#findComment-1755150
Does the TD-06 have T3 flange though?
Why don't you try one of the Garrett range. They a much, much cheaper than the HKS alterantive and every bit as good in their function and their quality. Try www.turbobygarrett.com for a starter. There are a large number of retailers, a search on this forum will give you a start. There is also an interview with their manager/director in this month issue of Zoom.
https://www.sau.com.au/forums/topic/96728-turbo-choice/#findComment-1756731
I've been told to have a look at The GT2860R, could be a goer, but not sure if I'm after something that big, I can't really find a mid-way point with any of the GT series. That's why I thought somehing from the TD range.
Edited by Savage Bliss
https://www.sau.com.au/forums/topic/96728-turbo-choice/#findComment-1757317
I think you mean the RS - just pays to be careful with the nomenclature. The GT28-60R is for the RB26 (You need two for that motor - part number 707160-5 or 7). But have a look at their comparison sheet for the medium sized units. Address should :D work http://www.turbobygarrett.com/turbobygarre...rison_sheet.htm
Then dig out the compressor maps to find out how the airflow matches in with your requirements. Don't just pick a turbo based on it's descirption of 300hp or 500hp or whatever hp.
https://www.sau.com.au/forums/topic/96728-turbo-choice/#findComment-1757540
I think you mean the RS - just pays to be careful with the nomenclature.  The GT28-60R is for the RB26 (You need two for that motor - part number 707160-5 or 7).  But have a look at their comparison sheet for the medium sized units.  Address should  ;)  work http://www.turbobygarrett.com/turbobygarre...rison_sheet.htm
Cool thanks mate.
https://www.sau.com.au/forums/topic/96728-turbo-choice/#findComment-1759165
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
