hey guys, i would like to go out for a saturday cruise now my 4 door line is going.....
i would like to find a nice straight section of road and line them up angle parked for a really big photo....... the evolution of the line..........
any way calling all 4 doors any age, from my 66 gt to the r34 4 doors if there are any out there, would love to go for a nice drive then maybe a barbie.... any one interested?
Edited by 66 skyline gt
https://www.sau.com.au/forums/topic/96830-calling-all-4-door-lines/
yep, I will be organising a large mid-January cruise to Victor and we will definitely have all models represented. Keep your eyes on the forums. Was going to try to do it before Xmas, but too many people have things on (myself included), so will make it mid-Jan instead. Will go-kart, jet ski or paintball while we're at it.
not yet Sean - in at Best being complied as we speak. Hope to have it back in the next week or so. :)
I want to catch up with you actually to check out your new springs to see if I want to head in the same direction. I'll give you a ring on the weekend perhaps. Are you interested in going to out Mallala or AIR to watch the practice day or street meet? Maybe we can catch up then?
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
