I use 32psi all round, and it feels tight, but not with too much road noise. I guess you should check what is written on your tyre?
I'm not sure about the 40psi mark... sounds like over-inflating when you're talking about stock tyre dimensions?
https://www.sau.com.au/forums/topic/96846-tyre-pressure/#findComment-1758858
Car manufacturers give recommended tyre pressures that are best for the smoothest ride, not the best handling.
If you like a nice smooth ride, put them to 32psi.
If you want the best handling put it up high like Duncan said around 38-42psi. I always have my tyres at about 38psi.
https://www.sau.com.au/forums/topic/96846-tyre-pressure/#findComment-1760656
There are 2 main things that happens with higher tyre pressures:
1/ Much firmer tyres, basically the same as fitting firmer shocks.
2/ Less tyre wall flex which is more important on high sidewalls like stock ones. Less difference with big rims/low profile tyres.
I took my old gtst (king springs, 10psi boost, otherwise stock, and with a passenger) around Eastern Creek in 1.57 on road tyres (Falken fk451) at 42psi
Of course it is all totally different with race or r tyres, they have very strong sidewalls and tend to be designed for 30-35 psi hot.
Like shyster said, manufacturers want comfort, not performance :)
https://www.sau.com.au/forums/topic/96846-tyre-pressure/#findComment-1762371
Yeah, I've noticed the same thing. I usually run about 33-34psi in mine (stocko rims/tyres) and I've found that the ride's really good, but the handling sucks; it rolls on the rims. But at higher pressure the corners aren't so hairy, so yeah I'd be going up around 38psi for handling... but for everyday use, the 32psi would do you just fine.
https://www.sau.com.au/forums/topic/96846-tyre-pressure/#findComment-1816903
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
