what i would like to know is the specs on this turbo
and how it would perform on a rb20 if possible as they told me the r33 and 32 hiflows differ
or even when it hits full boost..??
called GCG and supposedly they didnt know specs!?!?
thanks
We had a GCG ball bearing high flow on an RB20DET (170,000 ks' old), made 225 rwkw at 1.3 bar with 1 bar at 3,000 rpm, no boost drop off till 7,500 rpm, made good power to 8,250 rpm. Highly recommended.
:P cheers :)
yes but the RB20 and RB25 compressor housings are going to perform differently.
so if you use an RB20 turbo instead of an rb25 to start with you will have boost earlier but peak earlier...
Edited by CEF11E
Correct, but the difference is not dramatic, I don't think it would be more than 250 rpm later to 1 bar with the R33/RB25 turbo. The R34/VG30 turbine covers wouldn't be my choice, another 500 rpm or so I reckon.
:D cheers :D
what were the other support mods?
well, ill let you know how i go early january when i finish my tune
mods:-
- full 3" exhaust
- walbro fuel pump
- gtr injectors
- Z32 AFM
- remapped ECU
- FMIC
- bleed valve
- K&N pod
and adding the gcg stage 1 high flow within the next 2 weeks
Let me think;
POD, heat shield, substantial air feed
Performance metalcraft split dump
3.25" Nismo exhaust
No cat
OS Giken twin plate with flywheel
No HICAS
No aircon
Electric fan
Power FC with BCK
Castrol 10W60 oil
Oil cooler
Optimax
NGK copper plugs
One full day tuning on the dyno (plenty of time spent around the boost build rpm)
All on a 170,000 k's old RB20DET, that showed OK leak down figures for its age
:( cheers :P
i only made 254 hp at the wheels with stage 2 r33 hiflow turbo. This was on an auto r32 mods:
pod
3inch exhaust no cat
FMIC
z32 AFM
gtr injector 040 fuel pump
Have had the standard computer chiped (Romed)
Oh and mine is very laggy
i almost made that power with just an rb25 turbo..
get your car looked at i think
I agree.. i have an auto r32 with rb25 highflow (not gcg however) and checked today the revs vs boost, and its making 12psi (tubotech controller) by 3800rpm.. without any proper tune. No idea of power at the moment.
Tune coming tuesday for some figures.
