silver gts-t Posted December 2, 2005 Author Share Posted December 2, 2005 nF said: this is a good readgot a gcg hi-flow rb25 turbo going on my r32 now other mods include 550cc injectors and powerfc and the usual kinda shit i'll watch this thread and post results when/if i get them <{POST_SNAPBACK}> our cars sound similar apart from PFC, would be good to see the differance Link to comment https://www.sau.com.au/forums/topic/96852-urgent-gcg-stage-1-turbo-question/page/2/#findComment-1761563 Share on other sites More sharing options...
nF Posted December 16, 2005 Share Posted December 16, 2005 its being tuned right now should have results in a day or 2 Link to comment https://www.sau.com.au/forums/topic/96852-urgent-gcg-stage-1-turbo-question/page/2/#findComment-1797157 Share on other sites More sharing options...
Waldo Posted December 16, 2005 Share Posted December 16, 2005 man my engine must be buggered or sumthin...i have a high flowed turbo (not a GCG) but loooks exactly like it, and im only making 245rwhp and thats with tomei cams and 14psi and power fc....anybody know wat could be my prob?can i have a buggered head gasket? or could it be the rings? Link to comment https://www.sau.com.au/forums/topic/96852-urgent-gcg-stage-1-turbo-question/page/2/#findComment-1797212 Share on other sites More sharing options...
predator Posted December 16, 2005 Share Posted December 16, 2005 wind it up the boost to 18psi or so.. it's probably the only way you'll get power out of it.. then it will be laggy and possibly kill an old engine. Sounds similar situation to my highflow rb25 (its running 16psi at the moment).. not the best match for rb20. Link to comment https://www.sau.com.au/forums/topic/96852-urgent-gcg-stage-1-turbo-question/page/2/#findComment-1797290 Share on other sites More sharing options...
grim32 Posted December 16, 2005 Share Posted December 16, 2005 Waldo said: man my engine must be buggered or sumthin...i have a high flowed turbo (not a GCG) but loooks exactly like it, and im only making 245rwhp and thats with tomei cams and 14psi and power fc....anybody know wat could be my prob?can i have a buggered head gasket? or could it be the rings? <{POST_SNAPBACK}> i wish i had that, ive got 253hp@22psi. RB20 hybrid, exhaust housing too small. new turbo here i come......... Link to comment https://www.sau.com.au/forums/topic/96852-urgent-gcg-stage-1-turbo-question/page/2/#findComment-1797359 Share on other sites More sharing options...
nF Posted December 16, 2005 Share Posted December 16, 2005 18psi should be safe for most rb20s it helps force the air in your case is very odd waldo, cause tomei poncams i was looking at doing down the track Link to comment https://www.sau.com.au/forums/topic/96852-urgent-gcg-stage-1-turbo-question/page/2/#findComment-1797681 Share on other sites More sharing options...
Waldo Posted December 17, 2005 Share Posted December 17, 2005 yeah i still dont know wat it is, i have been checking all the vacuum lines for leaks, the only thing i havent checked is pluggin up the stock bov and putting big bolt clamps on the cooler piping Link to comment https://www.sau.com.au/forums/topic/96852-urgent-gcg-stage-1-turbo-question/page/2/#findComment-1797853 Share on other sites More sharing options...
silver gts-t Posted December 17, 2005 Author Share Posted December 17, 2005 my cars booked in for jan 9th, so we can compare more results Link to comment https://www.sau.com.au/forums/topic/96852-urgent-gcg-stage-1-turbo-question/page/2/#findComment-1797901 Share on other sites More sharing options...
nF Posted December 17, 2005 Share Posted December 17, 2005 ok i made 190rwkw at ~14psi which isn't *too* shabby to be honest no boost controller need a decent one to hold that can ~18psi Link to comment https://www.sau.com.au/forums/topic/96852-urgent-gcg-stage-1-turbo-question/page/2/#findComment-1797964 Share on other sites More sharing options...
silver gts-t Posted December 17, 2005 Author Share Posted December 17, 2005 nF said: ok i made 190rwkw at ~14psi which isn't *too* shabby to be honestno boost controller need a decent one to hold that can ~18psi <{POST_SNAPBACK}> post up a graph, and other mods.. Link to comment https://www.sau.com.au/forums/topic/96852-urgent-gcg-stage-1-turbo-question/page/2/#findComment-1798108 Share on other sites More sharing options...
predator Posted December 17, 2005 Share Posted December 17, 2005 sounds similar to mine.. nf: I think you'll make maybe 20% more power with raising the boost another 4psi or so... so thats quite a good result if you ask me. may as well post up my chart as a point of comparison. 16psi on highflow rb25 turbo (rb20 actuator), k&n panel filter, 3" exhaust right thru, highflow cat, hybrid cheap front mount 450x300x75, turbotech boost valve, SAFC.. So seeing as mine is AUTO, and non-powerfc seems about in range with nF above by taking 20-30% off. I don't think there was any temperature correction put in for the 32 degree day.. non-shootout .. So allowing 10-15%.. mine is about 150rwkw on any other dyno (probably feels about 150rwkw too). A fair bit of blowby at 16psi exhibited in my engine, whereas was none at 12psi... so any more isn't a good idea in mine at the moment. Link to comment https://www.sau.com.au/forums/topic/96852-urgent-gcg-stage-1-turbo-question/page/2/#findComment-1798320 Share on other sites More sharing options...
nF Posted December 17, 2005 Share Posted December 17, 2005 sorry don't have a scanner or camera here so i'll try describe also graph doesn't have RPMs so someone might have to convert in 3rd gear, peak power at 114km/h, made full boost by 82km graph is a nice curve too mods that are important: - split dump - splitfires - iridium plugs - k&n pod - 3 inch full exhaust with a hi-flow cat (crowbar brand) - the turbo is r33 gcg hiflow with i think the r32 actuator - 550x100x76 intercooler Link to comment https://www.sau.com.au/forums/topic/96852-urgent-gcg-stage-1-turbo-question/page/2/#findComment-1798368 Share on other sites More sharing options...
