Hey guyz have an R32 and when the car warms when im driving i get hot air coming thru the vents.
This happens while the CC unit is off, when i push the recycle button (the one with the arrow turing) it stops.
Should hot air be coming out if the CC is not on??
Any help would be appreciated
joe
https://www.sau.com.au/forums/topic/96875-constant-hot-air/
Sounds like the metal bar has fallen off or gotten jammed. In my R33, I can see it by going head-first, and on my back onto the driver side footwell. Looking behind the stereo etc, I could see the heaterbox (white), and behind that is a bar that controls the vents I beleive. If that's the right rod, it would open and close internal vents to the heaterbox. i.e open lets heat come from the heaterbox, closed redirects outside air through, and anything inbetween will mix outside and heaterbox air together. I hope it's a simple fix like that for you!
https://www.sau.com.au/forums/topic/96875-constant-hot-air/#findComment-1757831
joe
Firstly, switch the fan on and note the temperature. If the temperature is high this will result in hot air coming through the vents. Reduce the temperature. This sets the position of the fan temperature control unit (the split of the hot air to cold air) regardless of whether the fan is on or not.
I have also had the problem before due to the in-car air temperature sensor being disconnected. If someone accessed the centre panel recently to work on your stereo etc you may find the temp sensor was not reconnected following completion of the work. The temp sensor monitors the temp of the air coming out the small grille beside(?) the ash tray.
Hope this helps.
Edited by BH_SLO32
https://www.sau.com.au/forums/topic/96875-constant-hot-air/#findComment-1768695
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
