hi guy,
i currently own a 94 R33 gtst. and am (was) aiming for around 250rwkw. i currently have 225rwkw@ 15psi using a claimed 450hp T04 with PFC, 550cc Z32 ect ect... engine is unopened.
now the problem i have is that if i try to run more boost the knock levels start to increase... af/r are perfect 11.9 to 12.1 but is not making much more power on higher boost setting...
i still believe the turbo can reach my goals.... but am now starting to wonder what else could be holding me back???? intercooler, exhuast, manifolds ????????
what do you guys think???
Edited by skyman
https://www.sau.com.au/forums/topic/96904-want-more-power/
If it knocks due to pre-detination, could it be that the air in the chambers is too hot?
Do you have ajustable cam gears, and have you adjusted the timing when the PFC was done? I recken you might be able to squeeze a bit more out with cam-gear adjustment or something along those lines.
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1757804
I would say a quick set of tomie cams and forget the cam gears...
Thats what i am doing.... Found cam gears are hard to get right and found limited gains/loses....
wat power gains did you get from your cams??? where you able to run more boost??
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758124
I think you are pushing too much power with standard internals
240rwkw-250rwkw max with standard internals
plenium and do you hav a heat sheild and cai
mabe thremo fans
try 100ron and new tune as well
do you want power and or drivability
do you have a fuel pump and reg
james
Edited by Miller the hoon
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758132
Remember running thermo fans can be a pain...
Yes it creases less drag on the engine.... But when the fans kick in it puts extra strain on the alternator... So its it really worth it???
I did have a thermo fan on the hr31 only due to the lack of room after i did an engine exchange...
But found the temp to vary heaps and on a really hot day with the a/c on the thermo fan could not cope...
It was on almost all the time....
Id be checking out your intake temp and buying a set of cams.... 256 tomie's will do the job... Also a cai will help if you have a pod... Remember the colder the air goes in the colder it comes out....
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758144
mabe thremo fans
james
my aim is 250 so hoping internal will hold
plenium is standard and standard clutch fan, i have all standard heat shelds over the turbo and a good cold air intake system, i also have all suporting mods including pump and reg
and james i want both power and drivability dont we all!!!
thanks for the reply
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758154
Would a lightend flywheel do anything to power out put and clutch
any sliping
and last i can think of without doing internals is homing and porting your exhaust manifold or go after market 1
james
not sure if if a lightend flywheel does anything for power??? clutch isnt slipping
ill try to find someone to test my cooler, hoping that will be the problem.
if not ill might have to look into porting, manifolds and or cams
cheers
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758212
stock internals should be fine upto around 280rwkw, he certainlty wont be at any restriction of the plenum or intake at 225rwkw thats for sure. you can check to see if your loosing pressure by recording boost at the turbo outlet and just before the plenum to see if your dropping pressure. boost doesn't make power, airflow does. upping boost will only amplify your problem, it will add more heat. more heat = bad. drop the exhaust on a dyno run and see how much you make. if you make lots more (which im guessing you will) then you need to look into a 3.5" exhaust and a split dump system and big mouth cat as well will most likely help
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758213
if i can recall i have around 1.5 to 2 psi pres drop. will try the things you have mentions next week....
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758233
paulr33 if it is the exhaust how much are we talking about
i thorght 3'' with hiflow cat was good to 300rwkws
and skyman wat did your tuner say wat would he recomend
and wat ebc is it on the pfc and are they a good bc
james
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758236
james
turners not sure but thinks the turbo may be out of flow?
not using electronic one just a cheep daul stage one which has been holding nice steady boost for 3 years now....
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758256
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
