hi guy,
i currently own a 94 R33 gtst. and am (was) aiming for around 250rwkw. i currently have 225rwkw@ 15psi using a claimed 450hp T04 with PFC, 550cc Z32 ect ect... engine is unopened.
now the problem i have is that if i try to run more boost the knock levels start to increase... af/r are perfect 11.9 to 12.1 but is not making much more power on higher boost setting...
i still believe the turbo can reach my goals.... but am now starting to wonder what else could be holding me back???? intercooler, exhuast, manifolds ????????
what do you guys think???
Edited by skyman
https://www.sau.com.au/forums/topic/96904-want-more-power/
If it knocks due to pre-detination, could it be that the air in the chambers is too hot?
Do you have ajustable cam gears, and have you adjusted the timing when the PFC was done? I recken you might be able to squeeze a bit more out with cam-gear adjustment or something along those lines.
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1757804
I would say a quick set of tomie cams and forget the cam gears...
Thats what i am doing.... Found cam gears are hard to get right and found limited gains/loses....
wat power gains did you get from your cams??? where you able to run more boost??
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758124
I think you are pushing too much power with standard internals
240rwkw-250rwkw max with standard internals
plenium and do you hav a heat sheild and cai
mabe thremo fans
try 100ron and new tune as well
do you want power and or drivability
do you have a fuel pump and reg
james
Edited by Miller the hoon
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758132
Remember running thermo fans can be a pain...
Yes it creases less drag on the engine.... But when the fans kick in it puts extra strain on the alternator... So its it really worth it???
I did have a thermo fan on the hr31 only due to the lack of room after i did an engine exchange...
But found the temp to vary heaps and on a really hot day with the a/c on the thermo fan could not cope...
It was on almost all the time....
Id be checking out your intake temp and buying a set of cams.... 256 tomie's will do the job... Also a cai will help if you have a pod... Remember the colder the air goes in the colder it comes out....
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758144
mabe thremo fans
james
my aim is 250 so hoping internal will hold
plenium is standard and standard clutch fan, i have all standard heat shelds over the turbo and a good cold air intake system, i also have all suporting mods including pump and reg
and james i want both power and drivability dont we all!!!
thanks for the reply
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758154
Would a lightend flywheel do anything to power out put and clutch
any sliping
and last i can think of without doing internals is homing and porting your exhaust manifold or go after market 1
james
not sure if if a lightend flywheel does anything for power??? clutch isnt slipping
ill try to find someone to test my cooler, hoping that will be the problem.
if not ill might have to look into porting, manifolds and or cams
cheers
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758212
stock internals should be fine upto around 280rwkw, he certainlty wont be at any restriction of the plenum or intake at 225rwkw thats for sure. you can check to see if your loosing pressure by recording boost at the turbo outlet and just before the plenum to see if your dropping pressure. boost doesn't make power, airflow does. upping boost will only amplify your problem, it will add more heat. more heat = bad. drop the exhaust on a dyno run and see how much you make. if you make lots more (which im guessing you will) then you need to look into a 3.5" exhaust and a split dump system and big mouth cat as well will most likely help
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758213
if i can recall i have around 1.5 to 2 psi pres drop. will try the things you have mentions next week....
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758233
paulr33 if it is the exhaust how much are we talking about
i thorght 3'' with hiflow cat was good to 300rwkws
and skyman wat did your tuner say wat would he recomend
and wat ebc is it on the pfc and are they a good bc
james
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758236
james
turners not sure but thinks the turbo may be out of flow?
not using electronic one just a cheep daul stage one which has been holding nice steady boost for 3 years now....
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758256
    • Hello, everyone. I'm new to the forum. I have a 1989 Nissan Skyline R32 GTR. I have lost all power to the interior, including AC controls, the gauge cluster, turn signals, and windows. Stuff that still works includes the horn, brake lights, radio, and headlights. All fuses, in the interior and exterior boxes, tested good.  It starts and runs fine, just with no gauge power or anything stated above. No warning lights either. Things that I have tested: - Fusable link tested fine - No other fuses blown - Alternator good - IGN switch tested fine - With my power probe, I can backfeed power through the IGN pin to the plug on the back of the gauge cluster, and everything comes back on.    So my theory is something on the control side that sends the ignition power through the system isn't doing its job, or a wire is broken. (I would think that it is the ignition switch that would do that, but who knows?). The ignition relays don't fire (all relays tested good). So what tells them to fire other than the IGN switch?  I would really appreciate it if someone had some insight on this. I have tons of hours into this; I don't want to give up in defeat! I have the HD wiring diagram, but having all those wires laid out like that on one sheet of paper makes things pretty hard to follow.  Thanks for reading, and thanks for the replies.  Where should I look next? Thanks.
    • Install a MAP sensor pre and post throttle. Best data you could have for NA, then play with the bends and/or air box and see how much of inflection is created at WOT on the plot.
    • And gone to a new home
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
