hi guy,
i currently own a 94 R33 gtst. and am (was) aiming for around 250rwkw. i currently have 225rwkw@ 15psi using a claimed 450hp T04 with PFC, 550cc Z32 ect ect... engine is unopened.
now the problem i have is that if i try to run more boost the knock levels start to increase... af/r are perfect 11.9 to 12.1 but is not making much more power on higher boost setting...
i still believe the turbo can reach my goals.... but am now starting to wonder what else could be holding me back???? intercooler, exhuast, manifolds ????????
what do you guys think???
Edited by skyman
https://www.sau.com.au/forums/topic/96904-want-more-power/
If it knocks due to pre-detination, could it be that the air in the chambers is too hot?
Do you have ajustable cam gears, and have you adjusted the timing when the PFC was done? I recken you might be able to squeeze a bit more out with cam-gear adjustment or something along those lines.
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1757804
I would say a quick set of tomie cams and forget the cam gears...
Thats what i am doing.... Found cam gears are hard to get right and found limited gains/loses....
wat power gains did you get from your cams??? where you able to run more boost??
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758124
I think you are pushing too much power with standard internals
240rwkw-250rwkw max with standard internals
plenium and do you hav a heat sheild and cai
mabe thremo fans
try 100ron and new tune as well
do you want power and or drivability
do you have a fuel pump and reg
james
Edited by Miller the hoon
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758132
Remember running thermo fans can be a pain...
Yes it creases less drag on the engine.... But when the fans kick in it puts extra strain on the alternator... So its it really worth it???
I did have a thermo fan on the hr31 only due to the lack of room after i did an engine exchange...
But found the temp to vary heaps and on a really hot day with the a/c on the thermo fan could not cope...
It was on almost all the time....
Id be checking out your intake temp and buying a set of cams.... 256 tomie's will do the job... Also a cai will help if you have a pod... Remember the colder the air goes in the colder it comes out....
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758144
mabe thremo fans
james
my aim is 250 so hoping internal will hold
plenium is standard and standard clutch fan, i have all standard heat shelds over the turbo and a good cold air intake system, i also have all suporting mods including pump and reg
and james i want both power and drivability dont we all!!!
thanks for the reply
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758154
Would a lightend flywheel do anything to power out put and clutch
any sliping
and last i can think of without doing internals is homing and porting your exhaust manifold or go after market 1
james
not sure if if a lightend flywheel does anything for power??? clutch isnt slipping
ill try to find someone to test my cooler, hoping that will be the problem.
if not ill might have to look into porting, manifolds and or cams
cheers
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758212
stock internals should be fine upto around 280rwkw, he certainlty wont be at any restriction of the plenum or intake at 225rwkw thats for sure. you can check to see if your loosing pressure by recording boost at the turbo outlet and just before the plenum to see if your dropping pressure. boost doesn't make power, airflow does. upping boost will only amplify your problem, it will add more heat. more heat = bad. drop the exhaust on a dyno run and see how much you make. if you make lots more (which im guessing you will) then you need to look into a 3.5" exhaust and a split dump system and big mouth cat as well will most likely help
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758213
if i can recall i have around 1.5 to 2 psi pres drop. will try the things you have mentions next week....
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758233
paulr33 if it is the exhaust how much are we talking about
i thorght 3'' with hiflow cat was good to 300rwkws
and skyman wat did your tuner say wat would he recomend
and wat ebc is it on the pfc and are they a good bc
james
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758236
james
turners not sure but thinks the turbo may be out of flow?
not using electronic one just a cheep daul stage one which has been holding nice steady boost for 3 years now....
https://www.sau.com.au/forums/topic/96904-want-more-power/#findComment-1758256
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
