It could also be argued that that power figure looks a tad optimistic for an automatic RB25DET with the mods you have listed.
I thought my graph was optimistic until I saw this thread.
3 inch turbo back (stock cat)
FMIC
EBC
Pod
on Auto R33 GTS-T
It gave me 190+ (192 I think) but timing was all out so the setting on the EBC was put back a tad.
I'm contemplating a SAFC2 and I hope it will give me 195+.
  • Replies 75
This is an interesting thread
Security: Lets not mislead people into thinking that 50rwkw gains are achievable through the use of an S-AFC, especially on a car like yours that is virtually stock because they arent - end of story.
The ONLY way that you could find that much more power is if your car was running like absolute shite beforehand. The gain is not soley attritbuted to your S-AFC.
I'm thinking that his base timing was way off. Majorly retarded.
That's where the gains were had, I'm guessing.
Can someone explain how the timing or "base timing" as mentioned above can be changed? Last tune, only the SAFC was touched, nothing about timing at all - just wondering if this would help me squeeze past 200rwkw (only out by 5.4rwkw at the mo.)
I think the only way to do it properly is a replacement or piggyback ECU.
Base timing can be checked with a timing light.
It is adjusted by turning the CAS.
hmmmm picture's would help ay...
I have 255rwhp in an auto and you cant compare it to a manual
and 50rwkws could be gain if it was running like shit on 92 oct
and serviced air leaks fixxed 98oct and a border line good tune close to blow up
sit am wondering the psi run
turbo mabe hiflowed
james
well Nick, if you read my post properly it says he played with my timing also.
apparently my timing was off to begin with.
he advanced it half way through the tune when it reached around 168kw and it jumped to 184kw.
my point of this thread is that he actually picked this up. not only did he tune my safc, he also fixed my timing problem. its for that reason i thought i had to post this thread... he definately knows his cars.
CAS = ?
Sorry about the questions, just interested to know. Autos are very limited in what you can do to tune them, especially in the R34 where the stock ECU is quite stubborn :(
and just as a direct reply to your post.. 50kw is 50kw.
if the dyno was reading high then it doesnt matter does it?
my base figure would've just been lower also which still doesnt change a 50kw gain.
and ive also said that he played with timing and allowed me to close the gaps on my spark plugs.
tell me another tuner that would allow you to do these things and give the same power output for the same price (it cost me $200)
Great, im really happy for you, but perhaps you didnt read my post. I was making a general statement and hoping you would post your before dyno sheet and or clarify specifics of what hitman fixed up to bring your power up (which you have now done)
Dont get me wrong, its a great gain, but for the 3rd time, i was simply saying it is always a good idea to confirm for everyone what was going wrong before so everyone understands where you made up the 50rwkw so people dont incorrectly assume that if they go and fit an S-AFC they will get these sorts of gains.
Either way, it looks good, and your car should be a different car now :(
any shop will be able to do it considering theyve got a timing light.
I havent seen a shop that doesn't have at least one timing light
Timing on rb25's should be set at 15+or-2 degrees at 650 rpm .
What was your timing set at before ? It can make a lot of difference .If retarded it wont have any power , if advanced to much it may ping ( knock ) and you may blow it up .
I dont doupt the 50 kw increase if your timing was way out , but the power your car is making is fat to optimistic in my opinion . As i said before its an auto and you have the aid of the torque converter and second gear .
A good way to find out the true power that your car is making , take it to wsid and see what your terminal speed is , thats a very good indication of your average power .
im pretty sure my timing was off.
i posted a dyno graph showing the before and after curve.
so just to clarify, i got 147 on 3" turbo back, fmic, pod and 12psi
with retarded timing (i THINK it was sitting a few degrees under stock).
if my timing was spot on then im guessing i would've made around 160kw as my base. but you cant really tell.
also another thing i'd like to add is he said that sometimes the knock sensor on the safc screws with the timing, if the knock is high then somehow it will retard timing so he advised me to disconnect it.
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
