  • Replies 87
Posted Images
Spotted a black ceffy in May on Princess Hwy  :lol:
Then saw him again at drift prac in september. Havnt seen any others.
commmmon 4 door cruise  :)
yeah we really need 4 door cruise for VIC
only ceffy's i seen in VIC in the past year or so are
-meggala's greenish rb25 one
-greyish coloured stock looking ceffy going into deakin uni
-inarks previous black ceffzilla on numerious occations (on freeway, driftnats, chasers)
-One of the workers non turbs ones at holford motors
-oh and the one out my window.
I spotted a purple ceffie - Plates MYA31 - at redbank plaza QLD about three weeks ago.  Anyone here???
Also Dangerous Daveo on the Queensland MSC last weekend.  <_<
I saw you then too. Did you buy Fidels old cef??? Looks simlar, just in a LOT better condition than his was :P
There is also a blue one parked just down from Asian auto spares round springwood. And you guessed it, its got 'THE KIT' on it. ;)
No Fidel still got his, doing a rb26 convert or something. he got pics/info on CB
spotted someonestole lastnight ...well he spotted me first and was beeping and waving his arse off as he went past heheheh .... :lol:  :P
i thought i got excited when i saw another ceffy hahahhehhe  :lol:
Hay man, I don't remember lol
Although I would possibly have been coming back from terrigal or the city :P CERFIIIROOOOPOOWAAAH!!!!! :)
saw a goldish/champagne late model parked outside the stockland at penneathills(spell?) shops...
so i parked right next to it...and a 40+yo indian dude got into it...didnt even pay attention to my car... :(
probly thought it was a camry :rolleyes:
  • 4 weeks later...
  • 1 month later...
I have only ever seen KURSED's old Cefiro and the phantom white one with plates ASX.xxx around Chatswood but I am always in my daily A-B car.
Apart from that have never bumped into another fellow Cefiro driver whilst in my cefiro :P
NFI who the black cefiro is! Anyone here?
I spotted a green ceffy here in mackay,
turns out a guy bought it from someone down nsw.
Green with a r33 wing, anyone know who use to own it??
I'm also planning on coming down to Brissie in April, so I will have to see if I can meet up with some of you guys.. (knowing my luck i wont see a singel ceffy while I'm down.)
  • 4 months later...
theres always a nice White Ceffy parked around the corner from my house on Daniel Solander Drive in Endeavour Hills. Not a fan of the rims but it looks fat as with that massive kit (looks either URAS or Vertex)... sits nice and low and has the S1 early model tail lights.
actually looks a lot like yours Konect :D (going by the pic in your avatar)
It's probably not so relevant for me to post "Ceffie spottings" because Ceffies are very popular, and very common to see here in Bangkok....
but yesterday I drove alongside another black Cefiro with gold rims, and the same standard front bar as my car. Smoke billowing out the back of his car, so I figure his turbo is probably stuffed - that would explain why he was driving so slowly! ;)
Also yesterday at the local university I saw another black [with sunroof] Cefiro, and the other day I parked next to a grey Cefiro that had the TBOII kit on it.... grainy pic because I took it with my phone camera....
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
