When viewing other peoples post in threads that do not have any status's such as 'QLD Member', 'Exec' or 'Administrator', I can not see their warning level.
If I was to make a post in any thread, I can see my warning level.
Does this mean that only I am to see my warning level and no one elses warning level?
Does this also mean that I can not see other people's warning levels and they also can not view mine?
This is just a question in terms of asking about who can really see the warning levels of other people (as I know administrators can see anythin and everything).
If this cant be clarified.... I'll setup a temp invision board on my dedicated server and test it out myself which will help answer my questions and in turn, I can answer it on here to also give everyone an idea to what the answer is to my questions.
https://www.sau.com.au/forums/topic/96972-warning-level/#findComment-1760331
  • 3 weeks later...
Yeah I have the same thing but what is it for exactly?
I'm guessing it's used to keep flamers, bad poster's and so on in check or they get banned right?
So the lower I keep my % the better?
Sorry for the questions, I've just never seen this on any msg board I've belonged to.
Take care.
Cheers B)
https://www.sau.com.au/forums/topic/96972-warning-level/#findComment-1805856
Correct :cheers:
The warning system is just that, a warning system.
Users that act the fool and fail to follow the simple forum rules will normally have their warning level raised by a moderator.
If your warning gets high enough, you will cop a ban or a posting suspension.
Put simply, if you respect the forum and other users, and follow the rules, you will never have a problem :)
https://www.sau.com.au/forums/topic/96972-warning-level/#findComment-1806018
Yep I agree with that 100%. It's a great idea, one I wish my local 240 board would adopt as it's full of "kids". There is sooooooooo much flaming and imaturity that it makes my brain hurt.
Im always up for razzin someone and what not but nothing is ment seriously, it's just good clean fun. However, a lot of the guys go to far and it just gets out of controll untill a mod finally steps in to lock the thread. Flamer's never seem to get banned or even suspended.
Anyway, just wanted to say I think it's a great idea and glad to see the Admin and Mod's want to keep a good, clean board where everyone can enjoy there time here.
Cheers B)
https://www.sau.com.au/forums/topic/96972-warning-level/#findComment-1814698
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
