i have a rb25/30 which is not assembled as the work has just been completed.. and also easier for inspection..
$ 8500 ono or $7000ono with rb20det + boxincludes:
forged pistons & rings
cometik mls head gasket
head and main studs
heavy duty valve springs
arp rod bolts
desress & shot peen rods
close and hone rods
stainless valves
bore and hone
surface greind of block
linish crank
porting & throating
tunnel bore & hone block
2 tensioners
rb25 vrs kit
rb30 bottom gasket kit
big ends
mains
timing belt
brass welch plugs
head is a r33 rb25 its complete cams and all as been recoed and work done as stated above
ready to be put together
i pretty sure i got everything down
also have r33 manifold/ plenum, injectors-rail, and a few other bits and pieces
please pm me if you have any questions at all
Edited by upik14me
https://www.sau.com.au/forums/topic/97000-rb2530/
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
