Hey guys, is anyone here a fan of low cars
I just lowered the line and goddamn that thing is low now.
Didnt really know what to expect, just jacked it up and changed the springs. dropped it again and hmmm LOWRYDA!!
donna have to get those as plates. lol or BOUNCIN cos thazz the other thing it does now.
Anyways just looking for any opinions on lowness. anyone else got a lowered line but not with coilovers (coilovers hmpff why do it properly when you can just dump it) and would like to share with me their driving experiences in terms of handling etc.
And please no links to the whiteline website. lol
latas
RiaZ
Hey Adrian I will try to call you about the "view the dump & front pipe session" at EVO R
https://www.sau.com.au/forums/topic/9705-low/
  • Replies 60
Mine has Apexi coilovers which where far too low when I bought it. It used to scrape the tyres in the arches, and scrape exhaust bits on dips in the road. I lifted it 25mm, and it still below legal, but because I have stock body it rarely scrapes now. Except in my own driveway which has a big slope and a lump at the top. That 25mm didn't make a huge difference in handling, and its still set firm, but then I don't know how a stocker handles.
Might want to have the wheel camber checked, or make friends with tyre retailers :)
https://www.sau.com.au/forums/topic/9705-low/#findComment-147900
I have KYB Coilovers lowered below legal limit.. I must have the hardest suspension on earth!!
I have stock Type-M front bar, and it scrapes on just about everything. the middle of the exhaust scrapes on speed humps at most shopping centres. the rear muffler (it's angled) is FAR too low to reverse upto a kerb efficiently.. bah!
but all in all, the car handles like a dream.... looks dam schmick. So i'm happy.
https://www.sau.com.au/forums/topic/9705-low/#findComment-148028
When you lower em too low , and my front is right on that limit, then the front lower control arms actually invert and hang lower at the inner pivot than the outer mount on the hub.
This creates a rocking effect on patchy road surfaces and also most shock bodies have no upward travel left which means on reasonable bumps the stops are getting hammered.
Hence this is why you get the occassional crash over a bump.
Having said that , a line lowered till the sills on the floor is a sweet look.
As b2barker said , if lowered the camber goes to neg and on the rear it is hard to get it off as there is insufficient
adjustment.Inside tyre wear then becomes an issue.
Cheers
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-148073
100mm clearance off the ground is the legal limit,
but from the wheel centre to the mid of the wheel arch needs to be lime 320mm in the front and 330mm in the back.
mine is not near there.
hang on.....
just measured it roughly
front is like 300mm and rear is like 285mm
hehe
looks slammed. if i could just get some 18's
https://www.sau.com.au/forums/topic/9705-low/#findComment-149828
Cant roll a coke under mine.
My tyres hit wheels arches too - but as for making friend friends with tyre retailers i havent had a prob with tyres they have been 90% tread since ive had it in Aug. I would be more grovelling to the likes of pedders! The rubber bit that stops it hitting the wheel arch on mine has warn away and the shockies have packed up (i think that was the basic explanation) so they wanted to put new springs in it which will lift my front end a little but the ansewer to that was NO! so now i gotta get special shockies - i think - suspension isnt really my area of expertise i kinda say its making my CD player skip fix it but i dont want it any higher - like the difficult female i am. Oh and be prepared for lots of scrapes thats why i didnt want to take on mandurah in the next run because that place just is shocking for low cars i cant even get on grannys driveway cos the curb is too high.
https://www.sau.com.au/forums/topic/9705-low/#findComment-151648
reading back about what GTRken said about the stops getting hammered and the bouncy castle effect thats whats happened to mine - i think the stops are pretty much non existant now. But theres apparently a solution without making it any higher that will last for ages and if it doesnt my mechanic will be seeing what the inside of my boot is like!! Just dont play the CD player on bumpy roads and advoid country driving because you'll be itching to get out of it by the end.
https://www.sau.com.au/forums/topic/9705-low/#findComment-151655
Nizmo , what type of shocks are on the car.
If they are the usual Tein , Hks etc , they are designed for smooth racetrack style roads.
They have HUGE spring rates and the shock valving is usually so stiff it doesn't need the springs.
A few of us go to Wilkinson Suspension in Bayswater. He sells quality gear ( Bilstein, Koni , whiteline , superpro etc ) and can get you good shocks and springs that actually go up and down.
Cheers
( no I'm not on commission )
Ken
ps luv your signature hehe ...close the door.:lol:
https://www.sau.com.au/forums/topic/9705-low/#findComment-151694
Originally posted by Pva_Glue
also a condition known as "TItt Giggler" :P
It's been also reported to male genders... due to Man Boob effect
cheers
Joe
I think you mean Jiggler , joe .
Or do you mean joe Diggler ??
Cheers
( cracks me up , bwahaha )
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-151698
all sounds very expensive!! im the kinda person that likes to take my car to one place and have them handle it - too many cooks spoil the broth as i found out with my Z31. Ive been told estimate $500 to have it fixed - should last as long as i have car - sounds decent to me. I would rather spend the money on something that actually makes it go faster!!
https://www.sau.com.au/forums/topic/9705-low/#findComment-151861
$500 to repair the shocks, supply new springs and bump rubbers sounds pretty cheap.
I think Wilko does Koni and king springs for about $1100-1200 but at least you know they will work.
Trust me , decent suspension will make your car go faster , around corners and even on the ( heaven forbid ) dragstrip.
Cheers
(ndf )
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-151904
Oh and in reply to taking it to one place, nobody is an expert on everything ( not even phptf ) but if you know which specialists to take it to a better result will occur.
For instance I wouldn't take my car to Wilkinsons to get tuned but visavis I wouldn't take it to Exhaust dynamics for a w/alignment.
Cheers
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-151908
Hey Ken,
I resemble that remark. I always take my car to the best man/woman for the job. I too have super stiff suspension, and will be taking it to Wilkinson Suspension to let them have a look at it and recommend a handling package for racing.
Nizmo,
$500 will not get you very far when it comes to good suspension, I would shop around and check out what each are offering first.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9705-low/#findComment-152028
your right joe , that is an odd question.
Funny thing is , coming from you , it sounds perfectly normal:D
Answer is no, you would have to take the springs out and replace them with solid blocks and fill the tyres full of concrete cos they have a cushioning effect as well.
Cheers
( we get some weird ones )
Ken:lol:
https://www.sau.com.au/forums/topic/9705-low/#findComment-152325
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
