must be something with 19 yr old girls and lowered cars then Gradenko because thats how old i am. My car handled fine being the height it is before the stops packed it in - you still feel the road a little more than a standard but it wasnt enough to make the cd player skip back then.
If it aint broke dont fix it :starwars:
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-156761
  • Replies 60
If it aint broke dont fix it :P
But if the stops are broke then it is.
A properly setup suspension should only hit the bump stops occasionally , not all the time.
Even the rally cars only get the bump stops refreshed about once a season
If it ain't broke then don't fix it means that you spend your whole time trying to maintain the car.
Trick is to IMPROVE it , make it FASTER , make LIGHTER , make HANDLE , make it leap tall buildings in a single bound.....
:lol:
Cheers
Ken
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-157144
Im getting it fixed - it just takes a bit of money so once that comes in it'll be back to how it was before - which handled great it grips the road has hardly any roll just a back end that likes to slide out hahaha
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-157500
$500 here, $500 there, where does it stop? I am trying to be sensible about my car, but I need everything done now. I never thought too much about suspension, but my car is incredibly uncomfortable on a bumpy road. I have HKS adjustable suspension, but I have no idea about the springs or anything like that. When I asked my mechanic to lift the suspension he said it is at the optimum hieght for performance, and something to do with campher.
Is there a cheap way of making it run a little smoother?
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-160664
Youve also gotta realise that most Japanese springs and shocks, coilovers included and F'IN stiff. Like REALLY stiff. Pedders and Kings products provide a much nicer ride and in some cases better handling than the jap stuff simply because the car isnt tracking over bumps in the road all the time.
Ive got Tanabe shocks with Apexi springs and its about as stiff as id like to go, any more and it becomes jarring to drive. My mate in rocko has an EVO4 with Bridgestone Potenza coilovers... yes suspension made by a tyre company.... i have NEVER ridden in a more uncomfortable car in my life... felt like the shocks were just steel bars.
Red17
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-160684
haha i always thought fremantle catered for the lowered car lucky you werent up in the hills with us hillbillies - you only get one chance when you take on a curb up here - took on one about a year n half ago and lost!! My poor Z31 had to be towed away because i blew out a tyre and couldnt find the lock nut haha!
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-160730
If it's adjustable for bump you could try softening them off but it's probably the springs are 90% of the problem.
Ohh and it's Camber which is the inward ( negative ) or outward ( positive ) inclination of the front wheel from perpendicular.
LOL *campher*
That will stop the moths from eating the seats.
Cheers
Ken
https://www.sau.com.au/forums/topic/9705-low/page/3/#findComment-160749
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
