Hey Kids,
I've scored a Cusco 2 way LSD which has gone into my R32.
Does anyone have advice on whether it is possible or advisable to use the stock rear centre to replace the open front diff?
As far as I know the stock LSD is a 2 way jobbie, and I'm worried that it'll cause understeering under brakes in tight corners.
I don't know if shimming the clutch packs loose would avoid this or if it's possible to alter the standard ramps.
Has anybody tried this?
Thanks in advance.
You are all beautiful.
https://www.sau.com.au/forums/topic/97089-tripping-on-lsd/
Definately not possible. Rear diff is a 200mm crown wheel, front diff is something like 160mm.....the centre wouldn't even fit in the housing, let alone the front diff crown wheel.
https://www.sau.com.au/forums/topic/97089-tripping-on-lsd/#findComment-1762157
Yeah, manual says model number F160. Completely different critter, so stupid question on my behalf.
I do believe that there are such a thing as R160 mechanical LSDs kicking around in Dattos and Subaru WRXs. I wonder what sort of splining they use? Heh, would be funny to see the look on the face of wrexy drivers.
Basically I'm a tightarse and I'm trying to find a cheap way to get front LSD.
Anyone got a subie diff schematic?
Hmm the carriers in these pommy sube forum photos look the same as the gtr schematics
Edited by FurryBarry
https://www.sau.com.au/forums/topic/97089-tripping-on-lsd/#findComment-1762468
Non-STi rex's use an R160 with mechanical LSD as the rear diff (STi's use R180). The 'R' designation refers to the housing type, as does the 'F'. It _might_ be the case that an R160 centre fits an F160 housing, but frankly I'd be surprised if it was a 'bolt in' proposition.
Datto 1600's use an R160 diff in stock form although none came with an LSD (in Oz at least), and some have bolted in a rex centre, but usually an R180 is used because it's easy to fit and stronger. Some have even put in an R200.
https://www.sau.com.au/forums/topic/97089-tripping-on-lsd/#findComment-1762514
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
