  Mecha said:
Well im interested in all 4 windows :(. You cant get the front and back done correct?
You can tint the back and a small section of the top and bottom of the windscreen.
Premiere seem to be cheap for a reason..... their tint jobs have noticable gaps around the tops of the windows, something so highly cosmetic is worth spending a few extra bucks on to get a good job.
although i wasnt 100% happy (i am very fussy though) with their job, overall people were happy when we organised the group buy...
i have two mates who are interested in a group buy as well, if we can get some sort of numbers (no tyre kickers!) i can call John for you guys...
We've had 3 cars tinted, each by different companies.
In order of preference:
Tint-a-car- good job, the tint has lasted well.
Tint proffessor- got some cut marks on windows (external), possibly caused by blades while they were measuring/cutting film?
Premiere- gappy, wouldn't go back to them, and they do sedans for $100, hardly worth organising a group buy when you can get it that cheap.
Cool, so has anyone picked a date and a place for this group tint a car?
John from Premier Mitcham organised for us last time the highest quality tint that yhey have (about $400 i think) for $145 for the 35% for the coupes, about $30 or so more for the 4 doors...
most of us got 35% in the front and the 20% on the rears, which makes it legal, for $175 for the coupes..my mates s15 and mine turned out very good, only very faint couple of marks, and a few very small bubles at the rear that cant really be seen...as i said earlier i am very fussy...
so i think Premier tint was good to us, other people please post your thoughts on your tint job from the last group tint..
  Scotty said:
Hey SKY031
Thanks for keeping this on the agenda.
Just to let people know... I don't have anything to do with organising this... i was just throwing out a few personal opinions in an attempt to help people make an informed decision with their final choice of company.
  • 5 weeks later...
i had an Audi done on tuesday and asked John if i could send more members down...
as long as you tell John you are from SAU he will give the group buy discount...
just thought some opf you might still be interested...
hey brett, are you still using the F1 tint that tint-a-car uses, or something different now?
had F1 on my old car and couldn't fault it....now i've got the 33 with some real dark (love it) japanese tint, but its not the best job...
Hey guys, Bret Wines from Vip window tinting came around this morning to tint my 33. I am happy as with the job, makes a massive difference.
He uses quality tint that F1 use. He does lexus, volvo and even Ford cars. Going just by that you can tell he is very very good at what he does.
Just lettin you know he did a kick ass job, $150 cant go wrong. Even got a lifetime warranty. His num is 0419515511 if your interested.
Ill post pics up later today.
Cheers,
Mark.
    • It might be fine. I was just saying that I wouldn't trust it without testing it.
    • Traction wasn't bad, l couldn't give it everything off the line but was able to go WOT about half a second after rolling - good for NZ drag strips.   Like one run I did a 1.96 60ft and pretty sure I was on for a 12.4 but lifted early as I was on a 12.5 dial in, and still won haha
    • Nice one! I was going to take mine down to SMSP drags one Weds night. I'd love to compare it with my GTR which did a 12.3. The bum-dyno in the 335i says its quicker.   How was the traction @Lithium?
    • AFAIK I've seen other people recommend using the back of the balance tube as well. Andre Simon from HPA at least. I can't imagine it being that far off from ideal even if it was only used to drive a boost gauge from the factory.
    • Hi All, New member here, I've joined to help my son with an issue that is truly doing our heads in. I'll start with a bit of an overview. Chris carried out some modifications to the engine to try and extract just a little extra power out of the motor and make it a bit more efficient. Previous to this work, the car already had an upgraded exhaust, increased boost up to 14psi, modified standard turbo to metal impellers and slightly oversized, upgraded fuel pump, been dyno-tuned at JEM, and some other bits n bobs like coil packs etc. Before the current mods it was making 236rwkw at 14psi but after the new mods it now makes 209rwkw at 14psi. The work he carried out is as follows, timing belt service, water pump replacement, return to sump radium catch can, had oem head rebuilt and machined 0.2mm, fitted Athena cut ring head gasket 1.2mm thick, arp 2000 head studs, added rear prp head drain, added an external wastegate 40mm turbosmart welded off the stock manifold and plumbed back into a 3in dump. The car has been on the dyno and apparently the ignition is working, fuel flow and fuel pressure is fine, injectors are fine, spark plugs are working fine, Maf is working, O2 sensor is working, TPs sensor is working, VCT is working, CAS is working, boost leak test showed no boost leaks, compression test first crank cold 135psi and got to 150psi across all cylinders once cranking, timing is confirmed at tdc with a dial gauge and the cam dots line up, no blockages in intercoolerm throttle body or pre-turbo intake, no blockages in exhaust, cat conveter or down pipe, turbo looks fine and spins and wastegate looks fine and is new. Soz for all the detail but after all this, it has been in 3 times for dyno and each time comes back stating it's not going to make power. After the first (or second, can't remember now) trip to dyno we did find the timing out by one tooth and this improved things, but it is still well down. Does anyone have any ideas?  Any replies much appreciated as we're just not sure of which direction to take this. Regards Rob (Chris's Dad).
