I was trying to install my FMIC this arvo only to find out my car was one of them cars that need the support bar to be cut... decided to give up after that and send it in for someone else to fix it. Basically front bar is cut, and the hole to fit the pipe through is also done. Just wondering where all you people got your FMIC's installed, thinking in consideration to prices... thanks all !!!
https://www.sau.com.au/forums/topic/97113-fmic-where-to-go-for-an-install/
depends wich area u from, sonny from ultratune at fair field, does a very good job $200 straightfoward fit...
my car is with him now..
PM me if u want his number
alot of Nissansilvia guys go to him
pm me if u want pictures of his work...
cheers
Haz
Edited by MYSTR33
do what i did: buy a cooler kit and a case of jim beam and cola. Have a can. Go to your mates place who has a set of ramps to put the car on. Have a can. Take off the bumper bar. have a can. Remove old side mount cooler. Have a can. Remove old piping for side mount cooler. Have a can. Cut holke for new cooler pipe. Have a can. Attach the cooler to the car (i put it on about 10cms offset to one side because i was a bit pissed by now) Connect up pipes. have a can. Put bumper bar back on. Have a can. Look at the cooler through the bumper bar and notice its ofset. yell, scream and curse and stumbell all over the shop. Take some photos and have a few more cans. Throw up because youve had too many. Have another can and pass out in the backseat of your car.
Get woken up by best mates old man asking you why the fu(k you are sleeping in your car. Mumble something to him, pack up tools take car off ramps. Have a glass of water to make you feel better. Head to maccas for a greasy breakfast.
Make sure it gets done properly! :lol: I still havent fixed it, you cant notice it much unless you look at it for a good 10 secs or so. I think ill fix it next weekend.
what happend to the rest of the case if you only drank like 9 cans? also FTR a 700ml bottle of beam, a couple of big bottles of coke and a kettle is the way to go.
the rest of the case went to the mechanic as a thank you for fixing the mess at such short notice.
You bought good quailty piping man..
Glad the cooler is all working fine etc etc.. gd thing u got it done soon, coz its so damm HOT right now!!! cant imagine how hot it would be in engine bay.. ouch..
Yea took jason 3.5 hrs or so.. I was the supervisior.. hahahah.. Kept him at his pace n kept him alive from the damm heat..
Well enjoy your car man..
Yeh i mounted the Can to the FMIC piping hopefully it wouldnt move , its such a big piece of crap and its pretty stable also took out the silencer hopefully give the exhaust more flow. On a sidenote: Nothing wrong with the install of the Piping work yet, all running fine ... i just need to get the T join to see how much boost im running.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
