I was trying to install my FMIC this arvo only to find out my car was one of them cars that need the support bar to be cut... decided to give up after that and send it in for someone else to fix it. Basically front bar is cut, and the hole to fit the pipe through is also done. Just wondering where all you people got your FMIC's installed, thinking in consideration to prices... thanks all !!!
https://www.sau.com.au/forums/topic/97113-fmic-where-to-go-for-an-install/
depends wich area u from, sonny from ultratune at fair field, does a very good job $200 straightfoward fit...
my car is with him now..
PM me if u want his number
alot of Nissansilvia guys go to him
pm me if u want pictures of his work...
cheers
Haz
Edited by MYSTR33
do what i did: buy a cooler kit and a case of jim beam and cola. Have a can. Go to your mates place who has a set of ramps to put the car on. Have a can. Take off the bumper bar. have a can. Remove old side mount cooler. Have a can. Remove old piping for side mount cooler. Have a can. Cut holke for new cooler pipe. Have a can. Attach the cooler to the car (i put it on about 10cms offset to one side because i was a bit pissed by now) Connect up pipes. have a can. Put bumper bar back on. Have a can. Look at the cooler through the bumper bar and notice its ofset. yell, scream and curse and stumbell all over the shop. Take some photos and have a few more cans. Throw up because youve had too many. Have another can and pass out in the backseat of your car.
Get woken up by best mates old man asking you why the fu(k you are sleeping in your car. Mumble something to him, pack up tools take car off ramps. Have a glass of water to make you feel better. Head to maccas for a greasy breakfast.
Make sure it gets done properly! :lol: I still havent fixed it, you cant notice it much unless you look at it for a good 10 secs or so. I think ill fix it next weekend.
what happend to the rest of the case if you only drank like 9 cans? also FTR a 700ml bottle of beam, a couple of big bottles of coke and a kettle is the way to go.
the rest of the case went to the mechanic as a thank you for fixing the mess at such short notice.
You bought good quailty piping man..
Glad the cooler is all working fine etc etc.. gd thing u got it done soon, coz its so damm HOT right now!!! cant imagine how hot it would be in engine bay.. ouch..
Yea took jason 3.5 hrs or so.. I was the supervisior.. hahahah.. Kept him at his pace n kept him alive from the damm heat..
Well enjoy your car man..
Yeh i mounted the Can to the FMIC piping hopefully it wouldnt move , its such a big piece of crap and its pretty stable also took out the silencer hopefully give the exhaust more flow. On a sidenote: Nothing wrong with the install of the Piping work yet, all running fine ... i just need to get the T join to see how much boost im running.
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
