Basically im trying to get rid of all these parts, because they are no longer needed! Prices dont include postage, but i will organise it all and will post interstate. All these items are located in Rockhampton in QLD. PM me for the details or sms 0407112897. Sorry about having no pics, but if really needed, i can organise somthing, may take a couple of days though.
Item: R32 GTR Standard turbos.
Item Condition:85000kms, both working, im not too sure how to check for shaft play, but i think there isnt much shaft play at all. The turbo's worked abobroad minded personely fine when i had them on the car and i ran them at 1 Bar of boost while ive owned the car. 1 turbo is visually better looking then the other, but they are both still pretty good nick. No weird noises or smoke.
Reason for Selling:As per usual, i have upgraded to bigger and better things.
Price and Payment Conditions:$300 for the 2, not including freight.
Item: C.E.S GTR Dump pipes(Ceramic coated mild steel). fits standard GTR turbos.
Item Condition: BRAND NEW! But with a bit of modification, i had to taper the divider (wastegate thing) to fit my new turbos
Reason for selling: Couldnt fit them with my new turbos:( due to stupidity and being very tired while fitting my new turbo's. Too lazy to pull them out again and give it another go.
Price: $500 bucks!
Extra Info: Aparently these are some of the best locally made dump pipes going, written up in HPI and im sure other people back me up there.
Item: R33 3 Inch Stainless Exhaust into 4&1/2 inch tip***(not 5 inch, sorry)***, will be pretty loud. Not sure if its a GTST or GTR but from looking at the 2, they look identicle..?
Item Condition: Brand spanker. Never used.
Reason for selling: Its a bit hard trying to bolt a R33 exhaust onto a R32. Stuff up from person i bought it with and cant get refund so im selling it off.
Price: $450
Extra Info: this exhaust is absolutely beautiful, wish it did fit my car.
Edited by jwah
https://www.sau.com.au/forums/topic/97134-r32r33-gtr-parts-r33-exhaust/
Yeah ive been trying to find out, but ive spent ages looking at pictures of a 33 gtst and a 33 GTR and they look exatly the same.. Its hard trying to get someone to confirm it. All i know is a 32 gtr exhaust goes onto a 32 gtst. so yeah. I'll keep trying to find out.
Cheers
Would need to know DEFINITELY if it fits a GTST before I even think about any other questions!  That's pretty important info!
iijj
The only difference i can find in a R33 GTR exhaust and a R33 GTST exhuast is the dump pipes and front pipe. From the cat back, i am very confident that they are the same. I can not see a difference at all in the 2 exhausts. I can send you pictures if required to show you how they both look. But IF the exhaust was to not fit, i will offer a refund. But i dont think it would be nesercary.
Cheers
I'm interested in the 33 exhaust, but need to know if its bolt on for a gtst or gtr?
Everyone who is interested in the exhaust, please note that it is 4 and a half inches and not 5 as last said, sorry for the mistake, but i just guesstamated it, but i just mesured it before. Pics will hopefully be added soon. Sorry again.
Cheers
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
