I just purchased a r32 gtr and love it. its alot lighter than my buddys r33 gtr and i can feel the diffrence. my question is when i play with it compared to my friends 33 gtr, the attesa seems to act faster and more to the point that my 32 gtr does. is this becouse the software was better in the 33 being a newer car or what. is there a way to upgrade to a better controller to make the attessa react better? what do you guys do?? thanks
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/
you can add extra clutch packs to the front diff, or something like that to make the attessa better, also rear diff mods i believe
Your parts are probably a bit tired :P
Although, i'd be consulting an expert for that as its not something you wanna muck around with unless you know.
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1762699
You need one of the ATTESA controllers in my sig, you can get as much front torque as you need with it, more than makes up for the differences in the speed of the systems....then get back to beating the whale :P
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1762791
yes 32 has 10 times per second update,33 has 100 times per second.
also 33 has the transfer clutch preloaded(no slack)
and no it would be very hard to adapt the 33 stuff into a 32
actually i think its more like 32gtr updates ~4 times per second, 33gtr ~100 times per second, and the 33 V-spec is nearly 1000 times per second :P from what the magazines tell me, that is.
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1762903
is that update ratio to do with the computer? and can be increased with an Apexi PFC upgrade?. Front torque has never really bothered me, it onlt jumps up with quick accel from the line...my tyres are pretty good and I never step-out and need it to correct me :P
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1763646
Nope the ECU and ATTESA computer are different. Changing to a PFC wont make any difference to it.
The fact that you only get torque in a straight line is exactly why there are controllers, especially for r32s. With a controller you can dial up torque out of a corner instead of just getting oversteer. Not as much fun but its heaps quicker
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1763689
would it not be more practical in a drag race situation to run a unit that can hold the torque to one preset amount like the HKS or does the one r31 nismoid react fast enough that it is just as effective. would these units be better than say a r32 gtr vspec attesa controller that is if it will be a direct plugin and if i can locate one. thanks
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1763996
you are missing the point a little bit. those modules dont replace the attesa they just bend the signals going in and out to get a slightly different effect. they can't make it react quicker. what they can do is give you different amounts of torque split all the time. and alter the way it reacts to certain inputs.
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1764117
ok i guess that was what i was after was to make it react faster, but i guess if it can not i guess the next best thing would be controlling how much torque is going to the front for drag racing purposes. i am trying to track down a power fc pro to have the soft touch and launch control to help aid the skyline AWD ability. i was told by apexi usa that you can no longer get a pro model, are you guys able to still get them on your side of the pond. thanks again guys for all the tech support i get from this forum without all the HATE of american forums.
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1764165
Duncan - it appears to me from reading the thread that this only modified the signal when it is NOT at zero.
I am looking for the HKS style, and from boostdesigns comments, sounds like he is too.
For launch, the HKS style will be quickest (no engagement lag), and then the ones that Duncan reccomends (predefined torque split).
once you are up and moving, the HKS style will become a drawback, as you are turning all that extra drivetrain for no reason (plenty of traction). In a straight line, once you have grip, 4wd is a liability (drivetrain and weight).
Of course, if you could quickly switch of the HKS style unit....
Duncan's one sounds like the least amount of bother. dial in 50-50, and when there is no slip it will disengage.
Hey - perhaps you could swap attesa controllers (ha ha ha).
Good luck
of course, while the theory is correct (it'd better be), I cant answer from practice.
My gts-4 is still on a ship (or its somewhere in customs), due this week...
I want to get hold of a HKS style unit (constant) unit when it gets here.
Will search/post then.
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1765075
i thought it was somthing like that
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1766230
Sorry, to throw a spanner in the works, the controllers I can get and most other controllers eg grid dancer, are 0 use for drag racing.
The standard ATTESA computer gives max possible front torque in a straight line under hard acceleration
These controllers only help in corners.
The only controller I know of that will help for drag racing is the HKS drag adapter, which as mentioned dials up a fixed torque split. I am pretty sure it also disables all front torque over a certain speed.
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1766253
That is exactly what i am looking for Duncan. does anyone know where you may be able to source one of these units from???i tried all google searches and most race shops dealing with HKS with no luck. thanks
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1769335
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
