I just purchased a r32 gtr and love it. its alot lighter than my buddys r33 gtr and i can feel the diffrence. my question is when i play with it compared to my friends 33 gtr, the attesa seems to act faster and more to the point that my 32 gtr does. is this becouse the software was better in the 33 being a newer car or what. is there a way to upgrade to a better controller to make the attessa react better? what do you guys do?? thanks
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/
you can add extra clutch packs to the front diff, or something like that to make the attessa better, also rear diff mods i believe
Your parts are probably a bit tired :P
Although, i'd be consulting an expert for that as its not something you wanna muck around with unless you know.
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1762699
You need one of the ATTESA controllers in my sig, you can get as much front torque as you need with it, more than makes up for the differences in the speed of the systems....then get back to beating the whale :P
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1762791
yes 32 has 10 times per second update,33 has 100 times per second.
also 33 has the transfer clutch preloaded(no slack)
and no it would be very hard to adapt the 33 stuff into a 32
actually i think its more like 32gtr updates ~4 times per second, 33gtr ~100 times per second, and the 33 V-spec is nearly 1000 times per second :P from what the magazines tell me, that is.
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1762903
is that update ratio to do with the computer? and can be increased with an Apexi PFC upgrade?. Front torque has never really bothered me, it onlt jumps up with quick accel from the line...my tyres are pretty good and I never step-out and need it to correct me :P
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1763646
Nope the ECU and ATTESA computer are different. Changing to a PFC wont make any difference to it.
The fact that you only get torque in a straight line is exactly why there are controllers, especially for r32s. With a controller you can dial up torque out of a corner instead of just getting oversteer. Not as much fun but its heaps quicker
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1763689
would it not be more practical in a drag race situation to run a unit that can hold the torque to one preset amount like the HKS or does the one r31 nismoid react fast enough that it is just as effective. would these units be better than say a r32 gtr vspec attesa controller that is if it will be a direct plugin and if i can locate one. thanks
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1763996
you are missing the point a little bit. those modules dont replace the attesa they just bend the signals going in and out to get a slightly different effect. they can't make it react quicker. what they can do is give you different amounts of torque split all the time. and alter the way it reacts to certain inputs.
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1764117
ok i guess that was what i was after was to make it react faster, but i guess if it can not i guess the next best thing would be controlling how much torque is going to the front for drag racing purposes. i am trying to track down a power fc pro to have the soft touch and launch control to help aid the skyline AWD ability. i was told by apexi usa that you can no longer get a pro model, are you guys able to still get them on your side of the pond. thanks again guys for all the tech support i get from this forum without all the HATE of american forums.
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1764165
Duncan - it appears to me from reading the thread that this only modified the signal when it is NOT at zero.
I am looking for the HKS style, and from boostdesigns comments, sounds like he is too.
For launch, the HKS style will be quickest (no engagement lag), and then the ones that Duncan reccomends (predefined torque split).
once you are up and moving, the HKS style will become a drawback, as you are turning all that extra drivetrain for no reason (plenty of traction). In a straight line, once you have grip, 4wd is a liability (drivetrain and weight).
Of course, if you could quickly switch of the HKS style unit....
Duncan's one sounds like the least amount of bother. dial in 50-50, and when there is no slip it will disengage.
Hey - perhaps you could swap attesa controllers (ha ha ha).
Good luck
of course, while the theory is correct (it'd better be), I cant answer from practice.
My gts-4 is still on a ship (or its somewhere in customs), due this week...
I want to get hold of a HKS style unit (constant) unit when it gets here.
Will search/post then.
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1765075
i thought it was somthing like that
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1766230
Sorry, to throw a spanner in the works, the controllers I can get and most other controllers eg grid dancer, are 0 use for drag racing.
The standard ATTESA computer gives max possible front torque in a straight line under hard acceleration
These controllers only help in corners.
The only controller I know of that will help for drag racing is the HKS drag adapter, which as mentioned dials up a fixed torque split. I am pretty sure it also disables all front torque over a certain speed.
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1766253
That is exactly what i am looking for Duncan. does anyone know where you may be able to source one of these units from???i tried all google searches and most race shops dealing with HKS with no luck. thanks
https://www.sau.com.au/forums/topic/97154-r32-gtr-attesa/#findComment-1769335
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that green thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
