R32 Rb20det +r33 Rb25de/t Engine Parts
Item:r32 rb20det +r33 rb25de/t engine parts
Item Condition:used
Reason for Selling:clearout
Price and Payment Conditions:all negotiable
Extra Info:will post some items
i have all these engine parts make an offer and come get them.
rb25de block+girdle+crank
rb25de sump+oil pickup (SOLD)
rb25de pistons+rods (SOLD)
rb25de fuel injectors+fuel rail (red tops)
rb25de injector wiring loom
rb25de oil pump X 2 (1 SOLD)
rb25det coil wiring loom
rb25det oil+water lines
rb25det stock turbo (SOLD)
rb25det vvt head modified to suit rb30 missing coils+ignitor
rb25det complete inlet manifold+injectors+fuel reg
rb25de vvt cams
rb25de sump+pickup (SOLD)
rb25det exhaust manifold+heatshield
rb25de harmonic balancer
rb25det crank angle sensor
rb20det block+crank+girdle
rb20det sump +oil pick up
rb20det water pump
rb20det engine loom (manual) (SOLD)
rb20det engine ecu (manual) (SOLD)
rb20det cams+wheels
rb20det t3 ballbearing turbo (SOLD)
rb20det oil pump
rb20det oil+water lines
rb20det turbo heatshields
rb20det exhaust manifold+heatshield
rb20det inlet manifold (SOLD)
rb20det crank angle sensor
rb20det cam covers
rb20det coil cover (SOLD)
rb20det harmonic balancer ....(SOLD)....
Will sell all parts seperate or package them up whatever goes.
Will update this list as i go through what else i got sittin there.
Edited by johnosvlt1
  • Replies 91
rb25 head is complete apart from the coil packs,ignitor.
Yep its got valves and springs,cams,lifters,cam covers,timing covers,full gasket kit through it.
By modified its had the coolant gallery welded up and the vvt oil feed aswell.Machined flat its smick :)
Its had plenty of work done and will come with reciepts to show work done and costs.first person who sees it will take it.
 Share
    • Looks like a scam. It has all the telltale signs: - The "business" doesn't have a physical address or really any kind information listed - It's using a generic online store website template - The prices are ridiculously reduced. To good to be true cheap - Everything is in stock and can be ordered in any possible combination   I've seen a few of these for other products as well. Things like sunglasses for example. I'd say stay away from it! And maybe reach out to the real theskylineshed and let them know this exists. I doubt there is much they can do about it, but still.   I don't know if they would actually take your money if you ordered something. Or whether it is just for collecting credit card details to scam otherwise. I'm not game enough to try it.
    • Hi guys has anyone ever bought from this website theskylineshed.shop?? Not theskylineshed.com as I’m aware there is 2 similar but different sites.     has anyone had any issues with theskylineshed.shop???
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
