R32 Rb20det +r33 Rb25de/t Engine Parts
Item:r32 rb20det +r33 rb25de/t engine parts
Item Condition:used
Reason for Selling:clearout
Price and Payment Conditions:all negotiable
Extra Info:will post some items
i have all these engine parts make an offer and come get them.
rb25de block+girdle+crank
rb25de sump+oil pickup (SOLD)
rb25de pistons+rods (SOLD)
rb25de fuel injectors+fuel rail (red tops)
rb25de injector wiring loom
rb25de oil pump X 2 (1 SOLD)
rb25det coil wiring loom
rb25det oil+water lines
rb25det stock turbo (SOLD)
rb25det vvt head modified to suit rb30 missing coils+ignitor
rb25det complete inlet manifold+injectors+fuel reg
rb25de vvt cams
rb25de sump+pickup (SOLD)
rb25det exhaust manifold+heatshield
rb25de harmonic balancer
rb25det crank angle sensor
rb20det block+crank+girdle
rb20det sump +oil pick up
rb20det water pump
rb20det engine loom (manual) (SOLD)
rb20det engine ecu (manual) (SOLD)
rb20det cams+wheels
rb20det t3 ballbearing turbo (SOLD)
rb20det oil pump
rb20det oil+water lines
rb20det turbo heatshields
rb20det exhaust manifold+heatshield
rb20det inlet manifold (SOLD)
rb20det crank angle sensor
rb20det cam covers
rb20det coil cover (SOLD)
rb20det harmonic balancer ....(SOLD)....
Will sell all parts seperate or package them up whatever goes.
Will update this list as i go through what else i got sittin there.
Edited by johnosvlt1
  • Replies 91
rb25 head is complete apart from the coil packs,ignitor.
Yep its got valves and springs,cams,lifters,cam covers,timing covers,full gasket kit through it.
By modified its had the coolant gallery welded up and the vvt oil feed aswell.Machined flat its smick :)
Its had plenty of work done and will come with reciepts to show work done and costs.first person who sees it will take it.
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
