Basically if one where to put an RB26 into a GTS4 with the standard loom and computer could you also wire in a torque split gauge from a GTR and mount it in a pillar pod or something?
What does the gauge actually read off? the ECU or the attessa ECU?
If it is read off the attessa ECU could you wire a torque split gauge into the ECU if your still running the standard GTS4 RB20?
Thanks for your time,
Joel
https://www.sau.com.au/forums/topic/97181-torque-split-gauge-gts4/
