Doubt you will get an answer that will pinpoint the problem on here.
First thing to do is check that the cambelt is installed correctly with everything on top dead centre.
Then if it won't start, and you think the head may be the problem, check the compression, to make sure its sealed properly.
If compression is good, check for spark and fuel and then continue until the fault is found.
https://www.sau.com.au/forums/topic/97190-help-needed/#findComment-1763716
... the old cam has like a half moon bit on the end that goes intoi te sensor, this one has a full moon shape on the end, n e thoughts
The locating key on the new head is broken. You need to peer down into the end of the cam, you should see where the key used to be connected. Then you need to visualise where the matching key in the CAS would line up with the cam's key.
https://www.sau.com.au/forums/topic/97190-help-needed/#findComment-1764104
Well I think what you said before would be adequate. I'll see if I can get it going. Cheers for your help. Any other ideas you can give me; does anyone know if the rb20's changed cams at all
I think that is what you said.
AFAIK all the (silver) RB20s ran the same cams (the red ones were slightly different lift / duration).
I doubt it's a problem with the cams as such. You should be able to hear the engine firing, it's just that it's firing at the wrong time in the cycle.
The CAS and cam align on a set of teeth as well. The teeth are far enough apart that the engine will only fire when the CAS is close to the correct position. Worst case, you should eventually get there by moving the CAS 1 set of teeth at a time until the engine fires somewhere near the right spot.
https://www.sau.com.au/forums/topic/97190-help-needed/#findComment-1768325
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
