R32 Or R33
I sent off a message to a guy, waiting for his response if he can do it or knows someone.
Just remake the bracket. It's just bent steel with a nut welded to it. It is thinner material than you might remake it in. You just have to get the thickness right in places where it absolutely must be (and there might not actually be any such places. The same motor trimmer who you get to work on the outside of the seat would no doubt have done exactly this type of repair in the past.
Yeah I agree, it's almost impossible to get them out without inflicting some sort of damage to the subframe! Especially when you get excited with the air chisel like I did! I'm not fussed, it's a somewhat non-critical component in terms of inhibiting function if there were dags or slight damage to the bore of the bush location. Once you bolt it back up it never moves. It's not like a suspension arm that needs to move through a range of motion that damage would actually make a difference to.
Update: pulled the passenger bracket off and looks some what universal. the driver bracket is proper cooked and don’t see how I could get it fixed. my thought process is, buy a cheap passenger seat and swap the bracket over and foams as mine are cooked
Will definitely ask, I’m expecting that I’ll need to sell my left nut
