  • Replies 42
Posted Images
Rolled my car onto Bel Garage's dyno yesterday. I have attached torque and power curves.
The most we saw was about 990nm and 390rwkw, but my injectors were more than maxed at that level, so we took out a bit of boost.
awesome result, what setup u running? turbo/s, etc?
how come from 5100rpm its not making anymore power? (not having a dig, just a question)
Edited by StageZilla
I wish it made all of it's power by 5100RPM! The aim was not to make peak power anyway, but to get the most area under the curve.
I'm still running the useless laggy peaky GTRS turbos, but somehow, they don't seem so laggy now.
Oh...and the dip towards the top of the rev range is wheelspin on the rollers.
Edited by Mik
awesome result mate. 370+ kw at only 5100rpm is amazing :P
can i ask what type of cams you are running now? and injectors afms?
it must really hammer from about 4500 onwards.
nice! at what boost is it? 1.4? 1.5? these things are supposedly good for nearly 2bar. excellent for a stock stroke 26, would be pulling nice and hard by 4500. once you do your injectors, ive seen these hold power right up to 8grand!
what cams are you running?
beat me to it beer baron :P
Edited by SLY33
Stock bro, even has a stock airbox .....
Nice results there Mik - Get some larger injectors in there STAT!
Why would traction be an issue? It's only got 370rwkw... :lol: Seriously though...traction is not too bad, but I do have pretty sticky 275s all round and it does like to randomly break traction in 2nd when it comes on boost.
Nick...to be honest, I though 700s would be okay. They are about as big as I would like to go on a daily driven car. I'm also running a bit more rail pressure than I would like.
Also something to note is that the torque figures estimated by these dynologs are apparently pretty accurate....just ask Morgs and WilliamsF1.
Awesome Mik, I'd definately upsize those injectors and pump a bit of boost into it. The new motor sounds like its a good one.
Edit: Mine only made 350kw at BEL which on CRD was 319Kw at all four, as a reference. Has since changed.
Edited by Morgs
I don't really care about the numbers to tell you the truth (although the torque one is interesting).
So your car only made 319 at CRD? That's so odd...after what you made at SMW, and speaking to Jason, I would have expected heaps more than that.
Also, Tommy's car made 330ish at CRD irc and a bit under 300 on Bel's dyno in the same state of tune.
I'm more worried about the shape of the curve and how it drives, which is why we spend a couple of hours on the freeway cleaning up the spool-up.
I'll go to the drags eventually, it will be a while though because I'm flat out with work atm.
yes, but what cams and afms? :D
yes the curve does look very good. and like you said the dyno graph is really only relevant to you. It's just lets you know how much improvment you have been making.
Is that the same dyno Jerry made 240rwkw on with his car?
Nice result - doing anything else to it or are you finished? Whens it go to the drag strip? :D
No Andrew , i expect my car to make about 260-270 rwkw on that dyno, but my car is pretty gutless , just about everyone makes more power than me !
I will let you know what power mine makes on this dyno when she goes on it soon .
(yes, but what cams and afms?)
Beer Baron : refer to post 7 . There is plenty wrong with airboxes when you make that kind of power, but he wants a stock car .
Guest
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
