Righto people.....Have this issue, i want to convert to 5 stud stud pattern, the fronts are easy for me to do, just get some turbo rotors and thats that, but what about the ass end??? Mate has been told to use R32 GTR rotors but as the email he got was all in japlish he's got sweet f**k all else outta the email!!
Anyone done this conversion or know whats needed to do it???
Cheers!!
https://www.sau.com.au/forums/topic/97202-rear-brakes/
Yeah well easy enough to go to turbo rotors, but how do i attach them to the car?? I was thinking they might make a DR rotor in a 5 stud stud pattern (that would be way to easy wouldn't it) because i know they make the 33/32 turbo rotor's in a 4 stud stud pattern!!
I just want to go 5 stud for a greater selection of rims, cause they don't make many 4 stud wheels in the right offset for the DR, plus im already running the R3x caliper/rotor combo on the front with 25mm spacers to clear the rims and i want to get rid of those spacers!!!
https://www.sau.com.au/forums/topic/97202-rear-brakes/#findComment-1764376
question? are you going to re drill the hubs themselves to 5 stud or use a whole new hub? there is the s-14 rear end swap? just a little bit of work...
there was a set of s-13 5 stud rear hubs on ebay
There is always that option of redrilling and it would prolly be the easiest and cheapest way out, but i was going to try to do it properly..
Whats involved in doing the S14 rear end swap????
https://www.sau.com.au/forums/topic/97202-rear-brakes/#findComment-1767969
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
