i just removed wheel .. covered hub in news paper and wheel arches and side of car and sprayed in my garage with no wind ..
make sure u tape correctly and make sure you get all the paint off if you didnt mask the disc could smell funny or cause irregular braking which you obviously dont want
I did that too, took about 2hrs total, will post up some pics. I did my hubs black and calipers red (black car with nismo wheels). Plan to just file back the NISSAN lightly - prefer natural metal colour to the white.
  • Replies 155
Posted Images
no i haventseen the logo painted white.it whold look good against blue callipers.
before
after
The paint colour is still the best i have seen of any heat proof spray in a can.
This is the before a track day in summer and after.the heat has slightly faded the colour but it is still good none the less.
I think wat he Ment was, Taking them fully off Including Disconnecting the Brake lines and draining the system
Which is what I had originally Planned to do Untill i saw this thread! great Thread btw!.
My idea is to re-Paint the white, (why not give it all a freshen up I thought.), using a Fine Paint brush.
Edited by silverbulletR33
  • 4 months later...
Hey I know it's been like ages since I said I would do this, but I finally painted my Nissan logos white. I did an OK job, just used a fine paint brush and some cheapo white spray paint that I got from Super Cheap. I've had them painted for about 4 months now and they haven't chipped or faded yet. Sorry for the crappy pic (again).
  • 4 weeks later...
They look really good!! i have read this thread and have decided on painting mine gold with the nissan logo either, chome, black or green (like my car) i have begun by preping the brakes, by sanding them back. I have my calipers off the car, as i have a skyline r33 gts with rb25det conversion so i am going to put the brakes on as soon as i can, i thought while they're off why not freshen them up?? great thread!
hame
  • 1 month later...
I just took my Brake Calipers and rotors of again as i found the vht paint scratches to easy and i f**ked my nissan logo up(trying to paint it white) Now im going to paint them gold just not sure if i should have another go at painting the nissan logo white. Also can i use some type of clear coat to give them extra strength to stop the rotors from peeling when i change the wheels.
Cheers
Dave
hey guys i tried doing mine today i have preped the calipers and i used one can of duplicolour metalcast mc202 yellow with gold finish and it is not looking great at all! i have used the whole can on the two calipers and they look funny i'll post up pics asap
hamish
heres the pics, it like the paint wasn't thick enough or something, think i should get another car n go over the top? i did not use a primer but i was told by the guy at autobarn not to as the paint did not need a primer...
hamish. :D
it appears that the colour u choose doesnt cover easy, get a can of the ground coat for it cover it with that, then apply the other paint and it should come up nice
I just wrote a post in anodisation of calipers but Ill run it past your guys..
Screw white because it looks shocking.. If you do decide to do it .. get a nail painting brush and apply it.
If not when you paint your calipers either file it back when dry.. if you already have them painted then this is best.
Or when semi wet (i.e 2 mins after painting) use your thumb wrapped in masking tape to stick onto the nissan sign and pull off at speed.. Watch it come off.. If its not comming off wait for it to dry some more..
Just spray over it with clear as its easier to clean once you do that, hope that helps everyone here
H@ME.. Try spraying it again when the calipers are cold and not hot.. Either that or dont spray them on a humid or wet day .. Try shaking the can for longer and soaking it in boiling water (dry the can totally as ive dropped water onto the paint once and I had to strip it back - damn perfection crap)
Can in the water will make the paint mixture thinner and easier to apply for one.. For your first coat go light, increase in second and heavy in 3rd.. This will allow a shinny base .. then smash it with clear.. All heat proof..
H@ME if you want gold look up the anodisation section for brake caliper .. It will look alot like brembos on 34s.. Paint will look shithouse
Edited by DECIM8
thanks for the advice guys, i have read a few thread on here regarding painting brake calipers anodizing etc, the paint looks a bit better today it has now a nice shine finish to it. So should i go over the paint on it now in the dulicolour Mc100 ground coat then hit it again with MC 200, or should i just try a few more coats of th mc200? regards hame. here is a recent picture.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
