  • Replies 155
Posted Images
Hey, i got the VHT stuff, only cuz i spent about a week trying to track down a supplier of duplicolour metalcast (only to walk into a local supercheap to find out they had it after i already brought the vht stuff)
http://www.vhtpaint.com/anodized.html
the blue anodized + the silver under coat
got mine from autobarn caboolture
Hey, got my R33 GTS afew days ago, doing all little mods to it to make it look good in my eyes. Really wanting to do this DIY but the calipers are much different, guessing because its a GTS
Spraying these wouldn't look so good imo. Would it be practical to upgrade the calipers both for performance upgrade and for looks? + anyone know what rims they are?
Silly me, After making my initial post Donkeys ago, I forgot to show off the finished Project, Btw thanks again paul for a great Tutorial. worked a treat, also gave me a chance to fix up some other things i found wrong. I went with the Metal Cast Blue cause it is just awsome. Also I used Vaseline on the Nissan logo, before the paint, then just scraped the paint off with a Razor blade after painting.
  • 5 months later...
good thread!
i'll be doing mine in 'dupicolor metalcast red' as most agree that this is the best paint for the job.
i will also give it a base coat silver to help bring out the red BUT im not sure if i get the top clear coat...is this needed?
lastly, will this paint ever crack/peel if i track the car?
i didnt bother with the top coat, the finish of the anodized paint was enough for me
as for the cracking/peeling on the track - not sure on that, they say its rated up at 500 F (approx 260 C) intermittently, so how hot do your brakes get???
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
