  • Replies 155
Posted Images
Hey, i got the VHT stuff, only cuz i spent about a week trying to track down a supplier of duplicolour metalcast (only to walk into a local supercheap to find out they had it after i already brought the vht stuff)
http://www.vhtpaint.com/anodized.html
the blue anodized + the silver under coat
got mine from autobarn caboolture
Hey, got my R33 GTS afew days ago, doing all little mods to it to make it look good in my eyes. Really wanting to do this DIY but the calipers are much different, guessing because its a GTS
Spraying these wouldn't look so good imo. Would it be practical to upgrade the calipers both for performance upgrade and for looks? + anyone know what rims they are?
Silly me, After making my initial post Donkeys ago, I forgot to show off the finished Project, Btw thanks again paul for a great Tutorial. worked a treat, also gave me a chance to fix up some other things i found wrong. I went with the Metal Cast Blue cause it is just awsome. Also I used Vaseline on the Nissan logo, before the paint, then just scraped the paint off with a Razor blade after painting.
  • 5 months later...
good thread!
i'll be doing mine in 'dupicolor metalcast red' as most agree that this is the best paint for the job.
i will also give it a base coat silver to help bring out the red BUT im not sure if i get the top clear coat...is this needed?
lastly, will this paint ever crack/peel if i track the car?
i didnt bother with the top coat, the finish of the anodized paint was enough for me
as for the cracking/peeling on the track - not sure on that, they say its rated up at 500 F (approx 260 C) intermittently, so how hot do your brakes get???
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
