BTW The rods in the RB20DET-R in the HR31 GTS-R Gibson race car were stock so that should give you some indication of strength. ( Yes they were shot peened ).
Unless you rip a Gibson engine down and check, I wouldnt be so sure. I have read the same, and up to recently had little reason to doubt the claim...but now am starting to have my doubts...
my mate has put down 520rwhp on stock RB20 rods - they where only shot peened and ballanced...
He also turned that motor to like 8500rpm or something like that as well...
520rwhp is an awful lot especialy when turning 8.5k redline.
i would really like to see a dyno sheet of that pull.
Remeber the stroke of an Rb20 is fairly short so revs is not such a big problem. Shot peeing rods deos increase the strength of the rod considerbly.
As for them being able to take 520rwhp. That doesn't suprise me but I would have to see it to believe it.
How do the stock RB20DET Rods compare in size to the RB26DETT rods? (other than the length) :P
while revs are something the rb20 is capable of it does increace engine wear and the potential for something down there to let go.....
ive included a pic of the rb20's stock rods from when i tore down the engine and they felt and looked very beefy to me.
i guess the key to the rods holding power is a proper tune and making sure the engine doesnt detonate at all, which is what seems to cause failure.
Edited by carl h
Race car claims are sketchy to say the least.
The gibson cars also had a "stock" intercooler. But for some reason they are different to mine?
yer, its stock position i think, but thats about it.
They dont use the stock Nismo GTS-R manifold either :(
Wish i still have the RB20DET-R in mine. Not to use, just to anchor my boat with :lol:
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
