I went into autobarn today and the guy there was trying to sell me a blitz pod and said that they can install it in a way that will result in no defect notice for me.
I thought all pods will cause issues with the cops, can anyone confirm this with me?
he also said that i dont need a CAI as my car is a turbo, and the air sucked in, whether hot or cold will heat up due to the turbo.
he seemed to know his stuff.
https://www.sau.com.au/forums/topic/97242-pod-legal-issues/
salesman will say almost anything, trust me, i used to be a salesman in the sporting retail industry, it's like that everywhere.
Cops don't care how discreet it is, the pods have to be boxed up and secure
https://www.sau.com.au/forums/topic/97242-pod-legal-issues/#findComment-1763604
as far as i understand (in Vic anyway) Pod filters ARE legal
as long as....
it is a dry element (non oiled type i.e K&N=illegal)
the pod is secured to the chasis (via bracket usually supplied in kits, my Apexi Pods has them)
it is the only intake mod you have (not allowed fmic AND pod, if fmic is not standard)
does not make your car no longer apply to emission laws
Hope that helps
RellikZephyr
https://www.sau.com.au/forums/topic/97242-pod-legal-issues/#findComment-1763620
hey maybe ur right, the pod is a dry element one, as all blitz are, the guy did explain about the bracket that will hold it secure to the chassis. maybe it is legal then... i guess the only issue here is that i have a fmic.
ahh that sucks
maybe i should get a k&n panel filter to replace stock one n modify it to draw up cold air directly somehow.
thanks for the help guys.
:P
https://www.sau.com.au/forums/topic/97242-pod-legal-issues/#findComment-1763751
Technically the air that goes through the turbo is Exhaust so it is indeed hot, which is why the use of intercoolers are needed. The crisper/colder the air the more that can get into the engine.
Hot air expands right? - Therefore it takes up allot of room
Cold air doesnt - therefore theres less of it to take up room so more air and more fuel can be "forced" into the engine.
https://www.sau.com.au/forums/topic/97242-pod-legal-issues/#findComment-1763868
Sorry to say it but on both counts he's wrong.
A cop can defect you with a pod - there's no way around it they CAN do it. I have mine engineered and technically they can still defect me for it.
On the second count that's the stupidest thing I've ever heard of. If you think about it logically you can see he's wrong.
https://www.sau.com.au/forums/topic/97242-pod-legal-issues/#findComment-1763882
Werd to that! You can have a POD as long as it is in a box. There was a post on here ages ago about POD's vs Pannel Filters - Pannel filetsr came out on top. Also it works out easier and cheaper to get a pannell filter because then you dont have to worry about getting a new box for it - it goes straight into the stock airbox.
As for the salesman - he should be shot. Go kick him in the nuts.
https://www.sau.com.au/forums/topic/97242-pod-legal-issues/#findComment-1763946
thats not entirely true about the boxed up pod thing
there was a post not too long ago and the guy had a boxed up pod but the cop was still asshole enough to defect him for it
but as long as you have done the right thing then you can take it to court, win and maybe even put that cop behind a desk for 6 months
RellikZephyr
https://www.sau.com.au/forums/topic/97242-pod-legal-issues/#findComment-1764002
as long as....
Hope that helps
RellikZephyr
What he said. :(
https://www.sau.com.au/forums/topic/97242-pod-legal-issues/#findComment-1768591
If his "stuff" is how to fleece customers by talking a lot of crap, then yes he knows it.
If I were you, I would have just backed away from the salesman slowly, smiled and nodded, and then when I cleared the doors run like hell. Stupidity has a tendency to rub off, and you don't want any of it on you.
Where are you based? The "one intake mod" rule only applies in Victoria.
And as for pod filters, its always a bone of contention. I've spoken to some mechanics in NSW that have passed their blue slip course and were told by their teachers that it was legal. But the cops don't, and so even if its legal you'll get defected.
Better safe than sorry I say, and you'd want to box it in to keep the hot air from your engine bay for performance reasons anyway.
As for the CAI, Autobarn mustn't sell them if the salesman doesn't think they're necessary. Otherwise he'd be telling you that you needed 2 or something. Saying that a CAI is unnecessary because your turbo will heat the air anyway is like saying that getting punched in the face a second time is OK because you've already been punched once.
Your turbo is going to heat the intake air that passes through it. Part of this is through conductance since your turbo is running hot, and the other part is because of the gas laws that states that gas temperature and pressure are linearly related. If one goes up, so does the other.
So, logically, if your air is going to be heated up and hot air is bad for performance, wouldn't it make sense to compress the coldest possible air so your resultant compressed air temperature isn't as high?
https://www.sau.com.au/forums/topic/97242-pod-legal-issues/#findComment-1770508
:lol: well put and very true
CAI is always better than sucking in engine bay air
RellikZephyr
https://www.sau.com.au/forums/topic/97242-pod-legal-issues/#findComment-1776624
from wat ive sussed out my 32 has a vent into the stock air box through a slat near the lights and on mums 33 there is a snorkel so wouldnt that be a cai? not a large flow path but still, the question is if u have a pod u will have it suking the hot air from the engine bay, but a stock box with a less restrictive filter with the stock air flow from the front, wat would be better?
https://www.sau.com.au/forums/topic/97242-pod-legal-issues/#findComment-1780195
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
