I want it to purr like it does with standard exhaust, but gain some power.
will run them next to each other and ad a crossover later if it sounds crap.
Have a theory that the early turbo will create back pressure to the late turbo if the pipes are joined. Could be wrong, dont know too much about cars but would like to try it.
sb..
appart from the extra weight and difficulty in getting decent size pipe diameters to fit it is going to allow more head room for flow potentially.
As for sound? who cares. The sound of power is an easy one to get used to. It will sound different to a single if it makes more power then it sounds better in my opinion. For those hung up on sound why not get rid of the turbo and go NA with a set of extractors (thats where your logic will end up).
It will sound crap. There is no "if"
early turbo and late turbo? a RB26 isnt a sequentially turbo'd motor
Thanks for that, sounds like you saved me some greif, I allways thought they were identical turbos but someone recently told me they weren't. I thought they might be wrong cos i had never read anything like that.
cheers for the help!!
they are identical turbos mate, not sequentialy staged. Providing of course you own a GTR i suggest you run outside and have a look under the bonnet. or drive it. then tell us if you think it's sequential turbo or not.
oh yes! its a GTR, took it for a couple of hot laps around the block just to make sure, he he.
No i dont think they are sequential.
wish you could just throw one on to see what it sounds like.
I will have a twin exhaust on my RB26 in approx 6-8 weeks should chrissy not get too expensive
And this is from a person who has done this just a little more than once...
cross-over to balance it or it does sound... yuk!
originally you said a twin system would sound crap.now you are getting one but it will only sound good with a balance pipe.I guess then type/placement/diameter/brand of mufflers/resonators/cats etc is irrelevant : "they will all all sound crap"
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
