These are the BlaZt cables, the latest dedicated USB version, no USB adaptor needed and no box along the cable. They are 200cm long. USB Drivers are included.
I distribute for BlaZt and have negotiated with them to be able to run this pre-Xmas group buy for SAU ONLY. :P
I am limited to 30 cables, to sell in groups of 10... or end of January....whichever comes first
p+h will be $6 Australia wide
This pic shows the BlaZt USB cable (software is NOT included)
Payment to be by direct deposit and cables will be mailed out same day as funds clear my acct.
I have the stock here, so there will be no delays :D
Once I have the first 10 buyers I will post up my acct details and roll from there...
Cheers,
Caz... :D
Edited by caz
https://www.sau.com.au/forums/topic/97270-dedicated-usb-ecu-interface-cables/
Hi Iwells,
The cable is 200cm's long.
and sorry about the tiny pic up the top, I'll change it...not sure why it came out so small?? This one is better.... P1010007.jpg
Kind Regards,
Caz.. :P
Could you please post a larger picture?  What length are the cables?
Edited by caz
you can buy nissan datascan from caz also (i assume), best software overall.
for free software, check software links section of this thread. theres a couple more threads going on about software (search forum for consult)
Does this differ at all in functionality to the DIY kit sold here? (apart from the USB connectivity, of course)
http://www.skylinesaustralia.com/forums/in...showtopic=92853
all functionality mentioned in the diy thread would apply here, as they do the same thing (convert the raw serial data and make it available on a com port, either actual (rs232) or virtual (usb) for software to access).
Hi Dezz, have a look at my website and it will give you lots more info... :P
www.cazracing.com.au
excuse the stupid question, but what kind of things does this allow you do to your car?
  • 2 months later...
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
