I am getting my engine rebuilt at present with forged pistons. I have been informed of other upgrades. My car has N1 turbo's, AFM, Power FC, Electronic boost control, HKS adj cam gears, upgraded FMIC, Full 3.5 "exhaust without cat with twin dump pipes, Twin K&n pod filters, Upgraded Injectors, fuel pump, HKS twin plated clutch, lightened fly wheel. Got dyno tuned at 310@all wheels.
I am looking at getting N1 bearings, blue print engine build, new timimg belt, steel head gasket and water pump have been quoted about $1750 for this.
This is at end of budget already gone over. Are these engine mods well worth that price and worth it long term when asking that sort of power. I would expect about 330-350 KW@all wheels when completed with above mods.
Also is upgrading oil pump necessary was quoted about 850 for that, can't afford now. If I don't do that are the other mods for 1750 a waste of time.
Any responses appreciated.
https://www.sau.com.au/forums/topic/97271-upgrading-engine-in-r33-gtr/
I'm new to the engine build thing as well so don't take my word as gospel but heres my opinions from what i've learnt.
Bearings definatly upgrade - N1 or ACL i think? ...
Blue print engine build not sure what that invovles don't know if everyone does that or not...
Timing belt definatly - last thing you want to do is have you brand new engine's timing belt snap and kill your engine.
Head gasket - may as well do it especially if you're going to be running 20psi +
I'm also doing N1 oil pump and N1 Water pump. Once again saftey thing - don't want to cheap out on $800 on an oil pump to have oil surge kill my engine.... i think its worth it, its up to you tho.
If you are going to the expense of pulling the engine out, then dont skimp on parts else you risk potentially having to pull it out again later down the line if something goes wrong.
Heres a mini list off the top of my head (im still waking up so bare with me)
Forged pistons
New Bearings
Tomei oil gallery restrictor
Sump baffles
Full head service (You should be doing this with your build)
Standard rods will suffice for the power you want
Full genuine Nissan gasket kit (complete engine repair kit)
Tomei gasket kit (Metal head, inktake & exhaust gaskets)
N1 oil pump (Definately not $850, Just Jap sells for $499)
N1 Water Pump
Timing Belt
All drive belts
So in short, theres no point ripping the motor out, machining the block and fitting new forged pistons and rings, but refitting the standard oil and water pump etc, thats plain stupid.
Do it once, do it right - An engine build is really something you need to sit down and plan out rather than lauching into it un-prepared only to discover mid build that you cant afford to do the fundamental upgrades that are needed on a highly tuned car if you want it to last
theres a lot of support for the N1 water pump here, when in practise on the street a std one more than does the job adequately. its been reviewed many times that the N1 water pump has less blades than stock, and actually pumps less water at lower rpms that a street car would see. this is not what you want if you happen to get stuck in traffic.
definitly dont skimp on the oiling! good god man! :D
whats the cars primary use?
your building one of the greatest performance motors of all time to make around 500hp, "i cant afford it now"?! bah, just wait till you can afford it. as above do it once do it right, it will cost you thousands(!) and just as significantly time and frustration if the motor goes due to an oil problem, and then you have to start from scratch.
What kind of money is all this costing you ? Is the $1750 extra for the parts you have mentioned above ?You should always use new bearings in any engine built especialy a hot engine , 330-350 awkw is a lot of power . $850 is a bit over the top for an oil pump when retail from Nissan is 600-650 and you can get them a lot cheaper.
Blue printing means double checking everything , everyone should do some of it , again especialy on a performance engine . For than kind of power i would even use a new crank and new rods , rod bolts and head bolts or studs but thats just me , others will tell you your old rods and crank are fine .
Thanks everyone for yor responses. I am definetely getting oil pump, Forged pistons, N1 bearings, new timing belt, blue print and steel head gasket. I have been informed that oil pump very important so putting in the extra money. I have decided not to upgrade water pump as not really necessary.
I'm not sure if I will ever take car to track or not. I never planned to but might now after doing up engine should handle it fine. All I wanted was a sleeper looking car with kick arse power and maximum accellaration. Just want car to fly from take off.
I was never going to do a project like this but after walking away from a head on collision with a Nissan Patrol with a huge bull bar and I was in a 1985 Ford TX5 turbo a couple of months ago I decided always better sooner rather than later. (BLOODY DRINK DRIVER WAS ON WRONG SIDE OF ROAD AND DROVE OFF. BLOODY INSURANCE COMPANY STATED AS ONLY HAD 3RD PARTY WOULD NOT COVER ME AS I WAS PARTLY TO BLAME BY JUST BEING ON THE ROAD.)
By the way this site kicks arse due to the knowledge of Nissan owners. My MRS owns a 95 TT supra and posted a couple of questions on supra forums and got like one response by a moron who stated runs 19psi on stock ceramic turbos. It seem like they are all poor young americans who bag later model supras as they can't afford them. KEEP UP THE GOOD WORK GUYS. :)
Any reputable engine builder would not allow any short cuts without the customer specifically requesting(*and outlined on the job card) those compromises.A fully recon.motor is that.(including new radiator for warranty etc) .Anything else is a patch up.In fact,certain engine builders(eg mine) wont allow a motor build unless it is tuned in house. And justifiably so as it benefits builder and purchaser which should be self explainatory.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
