Map Sensors V's Afm Ecu
Also check the factory 2 wire coolant sensor is functioning properly and plugged in. Ignore the dash, the dash uses a different temp sensor.
Yes, it will fit, with the right engine mounts, plus a complete wiring loom. The CA is carby fed, yes? Then you need to add a complete EFI pump system (probably a whole tank) to get that to go. I don't know the 4 cyl stuff that well, but I'd be reasonably sure you'd need an SR gearbox, which will definitely need a clutch, and probably lead to needing tailshaft mods (although maybe you'll get lucky there). There will be more. Not from me. Just on the list.
ISO 61508/511 et al would tell you that that is a good way to fail a Functional Safety Assessment, V&V and Ausit. All of them. Do not pass go. Do not collect $200. Go back and do it again.
Unplug your stock O2, does the problem go away?
