I'm getting one of these for xmas and was just wondering if it is difficult to install myself or am i better off getting someone proffesional to help me. As i'm getting married soon i can't really afford to workshop it so if its easy I would like to do it myself.
Thanx alot guys and girls.
edit:/ P.S i know i could search guys but im at work and the computers at my work bite balls. Sorry for SAFC thread 2 gazzillion.
Edited by Psiker
https://www.sau.com.au/forums/topic/97282-safcii-install/
yo paul.. i just installed mine myself too.. Quite easy, theres a tutorial on here, but i noticed that the wiring colors on the R33 GTST ecu loom is totally different to the tutorial, other than that, pretty easy tho. I too can give you a hand if you want as im just around the corner in warnbro. I wouldnt bother paying for someone to do it. It took me about 30-45mins maybe to install, and im not exactly an auto electrician
https://www.sau.com.au/forums/topic/97282-safcii-install/#findComment-1766547
how do you guys go with setting it up to get the right a/f ratios
p.s. has anyone had a go at fitting there own fmic, just got one and interested in having a look at someones car close up to see what is involved, i am in warnbro
Edited by Pal
https://www.sau.com.au/forums/topic/97282-safcii-install/#findComment-1770328
Pal.. i'm in warnbro too. I fitted my own FMIC and SAFC2, more than happy to give you a few pointers. I got a Hybrid R33 GTST kit off ebay, and found it was pretty easy to install, but a few tricky bits that the instructions didnt tell you.
PS. you can come round and check out mine anytime, im just near the last drop. Ive just PM'd you my mobile number if you want to get in touch
As you can see by dyno graph a/f ratios seem pretty constant black line is final tune, just got it done at hyperdrive, took em about 45mins on the dyno to tune safc2. Very happy with their work
https://www.sau.com.au/forums/topic/97282-safcii-install/#findComment-1770347
Get hold of an AFR meter somehow and only make small changes.
As an SAFC is only a signal bender for the MAF taking out fuel is done by making the ECU think its under less load,the ECU then delivers the fuel needed for that load,BUT it also delivers the timing for that lesser load meaning more timing.When im tuning SAFCs and have to make large changes I plug our Scan tool into the ECU and monitor the delivered timing often having to leave a richer than ideal AFR but that is the safest method.
https://www.sau.com.au/forums/topic/97282-safcii-install/#findComment-1787626
that included me fabricating all the pipework (made from 304 grade 2 1/2" stainless steel) and getting a friend to weld it up, im quite sure it has increased my horsepower. done a 180 degee turn on outlet of intercooler and plumbed back into existing piping (same as psiker's) had to cut alot of the front bar out and move a few things around in front of the radiator. happy with the outcome. have to get it dyno'ed again now. do you think the safc2 will need to be tuned again? and do i need to reset the computer?
Edited by Pal
https://www.sau.com.au/forums/topic/97282-safcii-install/#findComment-1813147
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
