Theres no defined point - Gearbox especially
It will depend on how its been driven, condition/age, and power delivery.
well i notice you have a lot of power. have you had to upgrade/ replace any driveline parts?
its regarding a street gtr with approx 600-650hp at the fly
occasionally seeing the strip and track
Edited by druzilla32
604awkw and I'm still using stock diffs.
Gearbox is a matter of how you drive it like everyone else has said. 3rd will be the first to go once you get decent power but I managed to get 446rwkw in mine before I swapped to the OS gearset.
Stripped the stock gearbox down and it was still in perfect condition.
I broke a gearbox ~5 days after having my car back on road with a base tune (440rwhp) - but the box was in fairly poor condition to start.
I'd suggest if you're at the point of being serious about track/strip performance you'd want an aftermarket gearset, straight cut or otherwise.
Diffs have been ok so far as with shafts, but I don't exactly give it a hard time
you can blow one with stock power if you work at it. some nice flat shifting into second, and into 4th would be a good way to ensure that the synchros wear out in a matter of days, which will then lead to some nice fractured gears as you bang it into 4th and let out the clutch at 7000 odd rpm. if you treat it more nicely (ie no flat shifting) and use it the way a synchro box is meant to be used then it will be fine for a long time.
Most twin and tripple plate clutches for gtr's are solid centre. I managed to get a sprung centre nismo twin plate for mine but have still broken 2 gearboxes. 1st box blew third gear and the second box broke second gear under acceleration in gear. This was with 520rwhp on first box and 608rwhp on the second box. New box has 627rwhp to cope with and i dont think its gonna last very long, Maybe a couple weeks. Time for OS Gearset.
Edited by R32-GTS
Anyone know how much weaker the R32 GTS4 gearbox and Diffs are, what power can a GTS4 handle?
I have *heard* 300kw at the wheels. As has been said though, its how you treat it.
the gts4 has different ratios to a gtr, including a different final drive. Well, according to the specs anyway.
EDIT:: oops, wrong specs
EDIT2: As has been pointed out below, r32 gts-4 is different. Perhaps I should widen my perspective to include other models... Perhaps not.
Edited by ebola
GTS-4 and GTR gearboxes are identical, except that the R32 GTS-4's (with the RB20DET) used different ratios. The R33 boxes and diffs are identical ratios.
But driveline strength also must include the clutch and half shafts. The GTS-4 is considerably less than the GTR in both clutch capacity and rear half shaft diameter. It also uses four stud wheels.
If you get an R33 GTS-4 and put a GTR clutch in it, and upgrade the wheel hubs and half shafts, it will be identical to a GTR in both strength and ratios.
But an R32 GTS-4 will have different ratios, but could be made just as strong with the same clutch and driveshaft changes.
Have tou had the GTR and GTS4 boxes in pieces? Are the gear and sahft sizes the same ( apart from ratio).
Are you sure all R32 GTS4 turbos came with 4 stud wheels??
Sky30, I have not personally compared the two gearboxes side by side fully dismantled, but know someone that has. There is one bearing with a different Nissan part number, not sure which, but both bearings are physically interchangeable and probably make no real practical difference. It is the sort of production change that car makers sometimes make during a production run.
The 4WD gearboxes are essentially otherwise identical in all respects, and used in both GTR and GTS-4. Gears, casing, shafts, selectors, seals, transfer case, everything are absolutely identical.
Diffs are the same too. R160 in the front and R200 in the rear all are 4.11 ratio except the R32 which has 4.32 diffs. The rear LSD can be viscous, multi-plate, or electronic, depending on what was ordered. Some GTS-4s even have the electronic diff usually only seen in the V spec GTR, though that is extremely rare.
The R34 GTR with the six speed Getrag has different gear ratios and diff ratios again, (3.54, I think ?). The front diff is an R180.
Edited by Warpspeed
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
