Sky30,  I have not personally compared the two gearboxes side by side fully dismantled, but know someone that has.  There is one bearing with a different Nissan part number, not sure which, but both bearings are physically interchangeable and probably make no real practical difference. It is the sort of production change that car makers sometimes make during a production run.
The 4WD gearboxes are essentially otherwise identical in all respects, and used in both GTR and GTS-4. Gears, casing, shafts, selectors, seals, transfer case, everything are absolutely identical.
Diffs are the same too. R160 in the front and R200 in the rear all are 4.11 ratio except the R32 which has 4.32 diffs.  The rear LSD can be viscous, multi-plate, or electronic, depending on what was ordered.  Some GTS-4s even have the electronic diff usually only seen in the V spec GTR, though that is extremely rare.
The R34 GTR with the six speed Getrag has different gear ratios and diff ratios again, (3.54, I think ?). The front diff is an R180.
I was also tols the GTS4 transfer case has less clutch packs than a GTR?
GTS-4 and GTR gearboxes are identical, except that the R32 GTS-4's (with the RB20DET) used different ratios. The R33 boxes and diffs are identical ratios.
But driveline strength also must include the clutch and half shafts. The GTS-4 is considerably less than the GTR in both clutch capacity and rear half shaft diameter. It also uses four stud wheels.
If you get an R33 GTS-4 and put a GTR clutch in it, and upgrade the wheel hubs and half shafts, it will be identical to a GTR in both strength and ratios.
But an R32 GTS-4 will have different ratios, but could be made just as strong with the same clutch and driveshaft changes.
Ginkgo Biloba i was replying to this post.
Targa spec GTRs put out around 250rwkw, so not big power. But 30 6000rpm launches in 6 days as well as a season of 8000rpm race launches are a pretty good test.
Standard diffs, standard gearbox. We regularly have to replace gearboxes with synchro problems but we've never broken anything inside. Never had any trouble with the diffs they are a pretty strong piece of gear.
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
