Which Station do you listen to?
32 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
On the way to work this morning I noticed that regular hosts have gone on holidays, which got me thinking - which radio stations do you listen to???
My choices are:
Breakfast (6.00am - 9.00am) - Hughsey, Kate & Dave on NOVA
Drive (4.00pm - 7.00pm) - The SheBang on MMM
At all other times im a channel surfer
Share your thoughts on who's good entertainment and whose not.
https://www.sau.com.au/forums/topic/97310-radio-stations/
Listen to a lot of CD's at the moment as there seems to be a phase of crap music much like the movies. Used to listen to H,K,D a fair bit but generally channel surf.
At work listen to UK stations online either with listen again or live.
https://www.sau.com.au/forums/topic/97310-radio-stations/#findComment-1765070
usually a CD, but on the way to work early in the morn (5am) i flick between nova and fox, they have the highlights from the respective breakfast shows...both are funny, and i just switch between the 2.
those are the only 2 stations i really listen to, mostly fox
https://www.sau.com.au/forums/topic/97310-radio-stations/#findComment-1765152
I'm always flicking between MMM & Gold, there's just too much crap going round & I'm a bit over Nova & Fox.
The Cage in the morning, sometimes the shebang in the arvo, but they've been getting crap, so the ol' function button gets a work out flicking to the cd every 2 mins.
https://www.sau.com.au/forums/topic/97310-radio-stations/#findComment-1765677
    • Tried them, they leaked. I also foolishly bought some random rubber ones that leaked too.  Genuine and not looked back.    As always though sample size of one, and I could have made a mistake installing them.
    • Technically still manual process to set it first time though
    • Shit job but not hard. I'd use a piece of wood to knock the plastic lid open to avoid damaging it, use a vacuum to clean up the fuel sender lid also so crap doesn't fall in. I'd probably do pump and filter at the same time since you're already in there, I reused my OEM sock after a quick clean since the one provided wasn't long enough. Could also hardwire your pump if you feel inclined.
    • Supercheap auto sell this: https://www.supercheapauto.com.au/p/pat-plusquip-fuel-tank-lock-ring-tool---universal-kit/SPO3564082.html I own this and if you HAVE PATIENCE you can remove it without snapping lines and generally being incredibly angry, then said at doing this job. Sadly I've removed the pump about 75,000 times over the years. I don't know if you're a large lad or a smaller lad but my advice to you as someone who is 185cm is if you are my height or smaller, is to sit in the boot and take your time. Yes you can put the seal on. The seal goes over the white thing/lid (you will see how it 'slots' in) then the whole assembly presses into the tank. then you screw the lock ring on. I spent so much time doing things the wrong way by trying to mount the seal into the tank first, then putting the white fuel hat on in the space provided. Put it together first then it'll all go in. But seriously be careful about removing the hoses AND where the removal tool is moving relative to the plastic pipes coming out of the lid when you've removed it. IT IS BRITTLE So brittle in fact I have two spare lids, and would recommend buying a spare and having it handy before attempting to do this. May as well throw https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD in the tank as well, as this uses all stock plugs and such. You may need to/strongly recommend you re-use your OEM fuel sock or use the one supplied with a length of hose so it sits at the stock height.
    • The tension is automatic....if you follow the installation instructions Self adjusting tensioners are used when the chain/belt is expected to stretch during it's service life, but the downside is the tensioner itself can fail and cause a problem, while the RB system is locked once it is installed and doesn't have that risk
